Serial LCD for arduino
im looking for a serial LCD module for my arduino, fed up of having to wire l0 wires up or whatever.
need some recommendations
i can get my head around which would work do they have pins attached.
the seriallcd library page reccomends the Matrix Orbital LCD0821 display but it seems so expensive compared to regular modules
Hi Joss B Gray,
More like experience than a recommendation and it isn't a LCD;
I have a µOLED-160-G1(SGC) graphical color display from 4d-systems http://www.4dsystems.com.au/prod.php?id=79 It is not that big (1.7") but easy to interface with, has a micro-sd slot you can use to store data, an analog input pin to connect 5 switches (with resistors) to and a sound output pin. Havent tried the i/o pins yet though. You can upload your own fonts and has the posibility to run some small programs from the sd card with a serial command. Downside is that they aren't cheap at all.
Jeroen
Not affiliated to that company etc.....
You can make your own if you want, sounds like you already have the LCD.. if you have an extra atmega8, you can easily emulate the Matrix Orbital commands.
Look at the tutorial for using a serial LCD, this will work with the sketch below.
http://www.arduino.cc/playground/Learning/SerialLCD
Upload this sketch to an Arduino... I think the Atmega8 would be your best choice.. since it's cheaper, and then just connect the TX of the Arduino to the RX of the SerialLCDArduino. (And if you connect the TX as well, you can read the analog pins and send the data back, I added this, plus EEPROM read/write, just because I can.. they're the first commands in there)
Also, I use 13 for the backlight of the LCD, this way, I can turn the backlight on and off via the controlling Arduino, it helps for like warning you or blinking when there's an update.. etc. (69 = on, 70 = off)
#include "LCD4Bit_mod.h"
#include <EEPROM.h>
//#include <Streaming.h>
const byte backLight = 13;
//create object to control an LCD.
//number of lines in display=1
LCD4Bit_mod lcd = LCD4Bit_mod(2);
  pinMode(backLight, OUTPUT);  //we'll use the debug LED to output a heartbeat
  digitalWrite(backLight,HIGH);
  lcd.init();
  lcd.clear();
  lcd.printIn("   LCD Ready: ");
byte serial_getch(){
  int incoming;
  while (Serial.available()==0){
  // read the incoming byte:
  incoming = Serial.read();
  return (byte) (incoming &0xff);
void loop(){
  byte rxbyte;
  byte temp;
  byte addr;
  byte pin;
  int myVal;
  int val;
  rxbyte = serial_getch();
  if (rxbyte == 254) //Matrix Orbital uses 254 prefix for commands
    switch (serial_getch())
      case 50: // Read analog pin, then send value back
      pin = serial_getch();
      myVal = analogRead(pin)/4;
      delay(10);
      Serial.print(myVal, BYTE);
    case 64: // EEPROM Write (address, value)
      addr = serial_getch();
      delay(10);
      val = serial_getch();
      EEPROM.write(addr, val);
    case 65: // EEPROM Read  (address)
      addr = serial_getch(); // EEPROM address
      val = EEPROM.read(addr); //
      Serial.print(val, BYTE);
    case 69: //backlight on (at previously set brightness)
      // not implemented
      digitalWrite(backLight, HIGH);
    case 70: //backlight off
      // not implemented
      digitalWrite(backLight, LOW);
    case 71:  //set cursor position
      temp = (serial_getch() - 1);  //get column byte
      switch (serial_getch())  //get row byte
        //line 1 is already set up
      case 2:
        temp += 0x40;
      case 3:
        temp += 0x14;
      case 4:
        temp += 0x54;
      default:
      lcd.commandWrite(0b10000000 + temp);
    case 72:  //cursor home (reset display position)
      lcd.commandWrite(2);
    case 74:  //show underline cursor
      lcd.commandWrite(0b00001110);
    case 75:  //underline cursor off
    case 84:  //block cursor off
      lcd.commandWrite(0b00001100);
    case 76:  //move cursor left
      lcd.commandWrite(16);
    case 77:  //move cursor right
      lcd.commandWrite(20);
    case 78:  //define custom char
      lcd.commandWrite(64 + (serial_getch() * 8));  //get+set char address
      for (temp = 7; temp != 0; temp--)
        lcd.print(serial_getch()); //get each pattern byte
    case 83:  //show blinking block cursor
      lcd.commandWrite(0b00001111);
    case 86:  //GPO OFF
      //implement later
    case 87:  //GPO ON
      /*temp = serial_getch();
                               if (temp == 1)
                                     GPO1 = GPO_ON;
    case 88:  //clear display, cursor home
      lcd.commandWrite(1);
       case 152: //set and remember (doesn't save value, though)
       case 153: //set backlight brightness
       //not implemented
       //these commands ignored (no parameters)
       //case 35: //read serial number //USING FOR EEPROM//
       //case 36: //read version number
       case 55: //read module type
       case 59: //exit flow-control mode
       //case 65: //auto transmit keypresses
       case 96: //auto-repeat mode off (keypad)
       case 67: //auto line-wrap on
       case 68: //auto line-wrap off
       case 81: //auto scroll on
       case 82: //auto scroll off
       case 104: //init horiz bar graph
       case 109: //init med size digits
       case 115: //init narrow vert bar graph
       case 118: //init wide vert bar graph
    default:
      //all other commands ignored and parameter byte discarded
      temp = serial_getch();  //dump the command code
    return;
  } //END OF COMMAND HANDLER
  //change accented char to plain, detect and change descenders
  //NB descenders only work on 5x10 displays. This lookup table works
  //  with my DEM-20845 (Display Elektronik GmbH) LCD using KS0066 chip.
  switch (rxbyte)
    //chars that have direct equivalent in LCD charmap
    /*            case 0x67: //g
                       rxbyte = 0xE7;
                 case 0x6A: //j
                       rxbyte = 0xEA;
                 case 0x70: //p
                       rxbyte = 0xF0;
                 case 0x71: //q
                       rxbyte = 0xF1;
                 case 0x79: //y
                       rxbyte = 0xF9;
     */  case 0xE4: //ASCII "a" umlaut
    rxbyte = 0xE1;
  case 0xF1: //ASCII "n" tilde
    rxbyte = 0xEE;
  case 0xF6: //ASCII "o" umlaut
    rxbyte = 0xEF; //was wrong in v0.86
  case 0xFC: //ASCII "u" umlaut
    rxbyte = 0xF5;
    //accented -> plain equivalent
    //and misc symbol translation
  case 0xA3: //sterling (pounds)
    rxbyte = 0xED;
    /*            case 0xB0: //degrees symbol
                       rxbyte = 0xDF;
     */  case 0xB5: //mu
    rxbyte = 0xE4;
  case 0xC0: //"A" variants
  case 0xC1:
  case 0xC2:
  case 0xC3:
  case 0xC4:
  case 0xC5:
    rxbyte = 0x41;
  case 0xC8: //"E" variants
  case 0xC9:
  case 0xCA:
  case 0xCB:
    rxbyte = 0x45;
  case 0xCC: //"I" variants
  case 0xCD:
  case 0xCE:
  case 0xCF:
    rxbyte = 0x49;
  case 0xD1: //"N" tilde -> plain "N"
    rxbyte = 0x43;
  case 0xD2: //"O" variants
  case 0xD3:
  case 0xD4:
  case 0xD5:
  case 0xD6:
  case 0xD8:
    rxbyte = 0x4F;
  case 0xD9: //"U" variants
  case 0xDA:
  case 0xDB:
  case 0xDC:
    rxbyte = 0x55;
  case 0xDD: //"Y" acute -> "Y"
    rxbyte = 0x59;
    /*            case 0xDF: //beta  //mucks up LCDSmartie's degree symbol??
                       rxbyte = 0xE2;
     */  case 0xE0: //"a" variants except umlaut
  case 0xE1:
  case 0xE2:
  case 0xE3:
  case 0xE5:
    rxbyte = 0x61;
  case 0xE7: //"c" cedilla -> "c"
    rxbyte = 0x63;
  case 0xE8: //"e" variants
  case 0xE9:
  case 0xEA:
  case 0xEB:
    rxbyte = 0x65;
  case 0xEC: //"i" variants
  case 0xED:
  case 0xEE:
  case 0xEF:
    rxbyte = 0x69;
  case 0xF2: //"o" variants except umlaut
  case 0xF3:
  case 0xF4:
  case 0xF5:
  case 0xF8:
    rxbyte = 0x6F;
  case 0xF7: //division symbol
    rxbyte = 0xFD;
  case 0xF9: //"u" variants except umlaut
  case 0xFA:
  case 0xFB:
    rxbyte = 0x75;
  default:
  lcd.print(rxbyte);  //otherwise a plain char so we print it to lcd
  return;
Of course it doesn't have all the Matrix Orbital LCD commands.. so you won't get auto-wrap functions and such. (they could be implemented I'm sure, you still have like 3k space after you upload this to the Atmega8)
Hope this helps.
Anyways... just search Serial LCD in Sparkfun (spendy), but eBay isn't a bad place to look either.
I bought this one http://www.newhavendisplay.com/specs/NHD-0420D3Z-FL-GBW.pdf from DigiKey. It only cost about 18$. It is ridiculously easy to use. It only need three wires: +5V, GND and one digital out pin. No need to hassle with backlight/contrast pots, everything is programmatically. I used NewSoftSerial library with it.
