Serial LCD library, rolling my own, stuck
so I have a serial LCD 2x16 from radio shack, specifically Parallax 27977. it works nicely, been playing with it, makin it swear and say silly things (even has a built in mic, but I ahve yet to play with that). anyways rather than memorize the function hex commands, i want to write up a simple library to do those for me, and I can just continue to use Serial.write to display things on it. I have the following code written so far, but nothing seems to happen when used. I removed any input arguments (baud and channel) using the KISS debugging approach. hard coded to use serial1 so I can keep my pc connected and play.
/*parallax 2x16 backlit display
serial w/ speaker
pn# 27977 $35 at rat shack
0-7 CUSTOM CHAR
10 DOWN
12 CLEAR and return to 0x0, pause 5ms
13 CARRRAIGE RETURN
17 BACKLIGHT ON
18 BACKLIGHT OFF
21 DISPLAY OFF
22 DISPLAY ON no curser no blink, pause may be needed
248-255 DEFINE CUSTOME CHARS	must be followed by 8 bytes 5x8 grid
#ifndef LCD27977_H
#define LCD27977_H
#include "WProgram.h"
class LCD27977{
private:
	int channel;
	int baud;
public:
	LCD27977();	//locked on serial1
	~LCD27977();
	void on();
	void off();
	void BLOn();
	void BLOff();
	void clear();
#endif
#include "LCD27977.h"
LCD27977::LCD27977(){
	channel=1;
	baud=9600;
	delay(100);		//initizes serial on arduino, and saves channel number
	switch(channel){	//up to 4 channels to accomadate Mega
		case 0:
		Serial.begin(baud);
		case 1:
		Serial1.begin(baud);
		case 2:
		Serial2.begin(baud);
		case 3:
		Serial3.begin(baud);
LCD27977::~LCD27977(){ }
void LCD27977::on(){
	delay(100);
	switch(channel){
		case 0:
		Serial.write(0x16);
		case 1:
		Serial1.write(0x16);
		case 2:
		Serial2.write(0x16);
		case 3:
		Serial3.write(0x16);
void LCD27977::off(){
	switch(channel){
		case 0:
		Serial.write(0x15);
		case 1:
		Serial1.write(0x15);
		case 2:
		Serial2.write(0x15);
		case 3:
		Serial3.write(0x15);
void LCD27977::BLOn(){ //backlight on
	switch(channel){
		case 0:
		Serial.write(0x11);
		case 1:
		Serial1.write(0x11);
		case 2:
		Serial2.write(0x11);
		case 3:
		Serial3.write(0x11);
void LCD27977::BLOff(){ //backlight off
	switch(channel){
		case 0:
		Serial.write(0x12);
		case 1:
		Serial1.write(0x12);
		case 2:
		Serial2.write(0x12);
		case 3:
		Serial3.write(0x12);
void LCD27977::clear() {
	switch(channel){
		case 0:
		Serial.write(0x0c);
		case 1:
		Serial1.write(0x0c);
		case 2:
		Serial2.write(0x0c);
		case 3:
		Serial3.write(0x0c);
	delay(5);
my code compiles fine, but once uploaded does nothing. the following is simple sketch that works exactly the way you think it would
void setup(){
  Serial1.begin(9600);
void loop(){
//  delay(100);        //in mfr example BASIC code?
  Serial1.write(0x16);  //turns on deisplay
  Serial1.write("stupid world");
  Serial1.write(0x11);  //turns on backlight
  delay(4500);
  Serial1.write(0x0c); //clears screen and CR
  delay(10);           //needed after 0C command
  Serial1.write(0x12); //turns backlight off
  delay(1500);
this is my second class, and the last one was in processing and rediulosy simple
	channel=1;
	baud=9600;
		case 0:
		Serial.begin(baud);
		case 1:
		case 2:
		case 3:
Why are you using a switch statement with 4 cases to deal with a hardcoded value?
You are calling the SerialN.begin() function in the constructor of your class. Do you know whether your constructor is called before or after the HardwareSerial class is initialized? If not, then you need to take a hint from the HardwareSerial class, and create a begin() method.
Connected to what?
I am temporarily hard coding it to serial1, however I want the code to eventually be able to use any of the serial connections. I have a mega so I want to keep flexibility, but since I don't really know what I am doing I hard coded it until i get it to work on once connection I won't complicate things. I am digging thru a c++ book and trying to fiure out where I am misstepping.
I understand your point on the .begin() bit, I should be able to just copypasta the code and have my own begin function I do believe. Back to the grindstone.
oh the serial LCD display is curently conected to serial TX 1, the unit is fully self-suffecient, just needs power and serial commands.
