Serial loopback, TX to RX not working
Hi all. I have a project I'm working on and was running into a wall getting serial communication working, reading was fine, writing didn't seem to work. Unfortunately my device didn't have an LED that I could monitor if it was receiving, only transmitting. It was running through a level converter, and I suspected I had an issue there.
So I wrote the sketch below to simply write to a serial port on my Mega 2560, then read that port to see if I was getting the same data back; I wasn't. I took the level converter out, and simply jumpered TX to RX for Serial 3, and still had problems.
The sketch generates a random character, a-z, sends it out to both the serial console and Serial3, then waits for input on that same port, reads it, and prints is on the serial console. I'm never getting back the same character that I sent. From a hardware standpoint, I don't see why this shouldn't work, and I'm not spotting anything obvious with the software. Does anyone know what I might be doing wrong here?
  Serial.println("Starting");
  // set the data rate for the SoftwareSerial port
  Serial3.begin(9600);
  int c = random(65,90);
  Serial3.write(c);
  Serial.write(c);
void loop() // run over and over
  if (Serial3.available())
      Serial.println(Serial3.read());
      int c = random(33,55);
      Serial3.write(c);
      Serial.write(c);
  delay(100);
Serial reads & writes are bytes, not ints. Try changing c from int to byte.
Hey thanks, that fixed it. It's the little things that get you sometimes. :)
I was also outputting one of the values as a decimal instead of a character, so that further confused my output. My revised code is below in case this might help someone.
//  byte c = random(65,90);
  Serial3.write(c);
  Serial.write(c);
      Serial.write(Serial3.read());
      Serial3.write(c);
      Serial.write(c);
  delay(100);
