I've made Master/Slave via RS485 using serialEvent.
Here is the code for Master :
String inputString = ""; // a string to hold incoming data
boolean stringComplete = false; // whether the string is complete
String poll = "*00100011110001111;";
int i = 0;
// initialize serial:
Serial.begin(19200);
// reserve 200 bytes for the inputString:
inputString.reserve(200);
pinMode(2, OUTPUT);
poll.setCharAt(1, 'a' + i++);
if(i > 10) i = 0;
digitalWrite(2, 1);
delay(1);
Serial.println(poll);
waiting();
digitalWrite(2, 0);
delay(1);
response();
void response() {
if (stringComplete) {
Serial.println(inputString); // echo response from slave device
// clear the string:
inputString = "";
void serialEvent() {
while (Serial.available()) {
// get the new byte:
char inChar = (char)Serial.read();
if(inChar == '-')
inputString = "-";
inputString += inChar;
// if the incoming character is a ";", set a flag
// so the main loop can do something about it:
if (inChar == ';') {
stringComplete = true;
void waiting() {
while (!(UCSR0A & (1 << UDRE0))) // Wait for empty transmit buffer
UCSR0A |= 1 << TXC0; // mark transmission not complete
while (!(UCSR0A & (1 << TXC0))); // Wait for the transmission to complete
Here is the code for Slave :
pinMode(3, OUTPUT); // enable pin for rs485
digitalWrite(3, 0);
delay(1);
digitalWrite(3, 1); // enable send
delay(1);
Serial.print(inputString);
waiting();
digitalWrite(3, 0); // enable receive
delay(1);
inputString = "";
if(inChar == '*')
inputString = "-";
inputString = inputString.substring(0, 7) + "111222333444555666"
+ inputString.substring(7);
void waiting() {
The message between Master and Slave is attached, Master start with "*" and Slave start with "-"
The problem is Master always get lack of response from Slave one step,
actually it is acceptable but I wonder if there is a way to make it better,
I knew that serialEvent only work after loop but do not have idea how to solve this.
Any idea is welcome.
Thanks in advance,
