serial monitor and IR codes, pauses + error codes
Hello, I have problem. First code from remote is ok, first is buttom code next is repeat code. But if I touch button longer time (longer than 2-3 seconds):
E318261B -ok button code
FFFFFFFF -repeat code
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
4CB0FADD -very weird codes
4DB61D87 -very weird codes
FEAC02E5 -very weird codes
nothing next
Nothing next but my finger is still on bottom. TX LED on arduino is not active, remote control is still blinking.
Second time:
E318261B
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
4CB0FADF
4CB0FADD
FCABFFBF
(nothing next)
Third time:
E318261B
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
FFFFFFFF
4CB0FADD
C40BD817
83DD14E7
4CB0FADC
(nothing next)
I do not know where is problem. I was tested 5 remote control. Two arduino - uno, mega. Still first repeat codes are ok, next I have pauses between codes + error/weird codes and completely stop. Speed is 9600 boud. I was tested much more speeds.
program:
#include <IRremote2.h>
int RECV_PIN = 46;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
delay(100);
Can anyone help me? :frowning: Thanks!
Which version of the IRremote library are you using?
I have something with name "IRremote2.h". But now I was tested this: https://drive.google.com/file/d/19ZyPjEdDir8eEEVjOAlhS6GV8TyMRCB8/view It use my friend. I was send him code in toppic up. In his case it is working correct.
I tested lot different pin but it is still same.
Maybe problem with sensor? I can not believe but maybe...
And sorry for my english. I hope it is readable :smiley:
Sorry, missed that you don't use the usual IRremote library.
I have arduino 1.8.3. without update. If any library is inside I can try it. But I do not how.
