Serial monitor and switch case
Good day,
I am using a potentiometer to adjust the brightness of individually adressable LED, aka the NeoPixels. By using Serial monitor I am sending letters to the board to switch between different programs. With the code I got now, I can adjust the brightness, but when I try to switch to another statement; let’s say after typing “a”, then bringing the LED to a desired brightness level, I will type “b”, but I am getting stuck in case “a”. As an easy solution to that I tried closing and opening the Serial monitor, then typed another letter and it works but the brightness level is that of the previous case. Whenever I switch to another case, I need the LED to be completely off, so that when I start using the potentiometer first value would be 0. Can anyone help this noob please?
#ifdef __AVR__
#include <avr/power.h>
#endif
const int PIXEL_PIN = 10; // NeoPixel input on digital 8.
const int POT_PIN = A1; // Potentiometer output on analog 0.
Adafruit_NeoPixel strip = Adafruit_NeoPixel(400, PIXEL_PIN, NEO_GRBW + NEO_KHZ800);
int alpha = 0;
int reading = 0;
char useCase;
  strip.begin();
  strip.show();
  if (Serial.available()){
    useCase = Serial.read();
    switch (useCase){
      case 'a':       // Front, Statisch, Rot
      while(useCase == 'a'){
        reading = analogRead(POT_PIN);
        alpha = map(reading, 0, 1023, 0, 255);
        Serial.println(alpha);
        strip.fill(strip.Color(alpha, 0, 0, 0), 116, 353);
        strip.show();
        delay(100);
      case 'b':       // Front, Statisch, Grün
      while(useCase == 'b'){
        strip.fill(strip.Color(0, alpha, 0, 0), 116, 353);
        strip.show();
        delay(100);
//some other useCases
        while (useCase == 'a')
          strip.show();
          delay(100);
Once in case 'a' when will useCase not be equal to 'a' thus allowing the case code to end ? Do away with the while loop and let the loop() function do the looping for you. To do this you need to take the switch/case out of the test for Serial data being available so that the value of useCase stays the same until a different value is entered
You might also change your read statement to:
    useCase = tolower(Serial.read());
just in case the user has the Caps Lock on.
for further interest..
the problem is not always the code I guess. Potentiometer is a mechanical device and even though I change the code to reset the value to 0 after every use case, it physically cannot start at 0 again, since the user previously would have adjusted the value to something else.
