Serial monitor/Arduino Uno/Servo control
I found this code online - I'm just trying to control a servo via my laptop keyboard. It's kind of worked, when I use the serial monitor in the Arduino IDE. But it wasn't very controllable at all.
What happens is as soon as I press a or d the servo rotates in one direction and doesn't stop. Is anyone able to see why this is the case?
I'm a bit familiar with python but by no means fluent. I only know what this code is supposed to be doing by the notes with it.
((The wiring is the same as found here if relevant:
http://www.instructables.com/id/Controlling-Servo-motor-using-Keyboard-input/ ))
Any guidance would be greatly appreciated.
#include<Servo.h> // include server library
Servo ser; // create servo object to control a servo
int poser = 0; // initial position of server
int val; // initial value of input
Serial.begin(9600); // Serial comm begin at 9600bps
ser.attach(9);// server is connected at pin 9
if (Serial.available()) // if serial value is available
val = Serial.read();// then read the serial value
if (val == 'd') //if value input is equals to d
poser += 1; //than position of servo motor increases by 1 ( anti clockwise)
ser.write(poser);// the servo will move according to position
delay(15);//delay for the servo to get to the position
if (val == 'a') //if value input is equals to a
poser -= 1; //than position of servo motor decreases by 1 (clockwise)
You may exercise the example of this post to see how servo is controlled by sending message from the Serial Monitor of the Arduino IDE.
Rachael_N:
The program you posted seems to be for a regular servo and I suspect you have a continuous rotation servo.
...R
