Hi
I am attempting to develop a library, I think my serial monitor is showing or even potentially causing resets from the loop of the test sketch. The test sketch for the library looks like this.
#include <Lightman.h>
#include <Bridge.h>
#include <Console.h>
#include "Tlc5940.h"
Lightman larray;
Bridge.begin();
Console.begin(); // Initialize Console
while (!Console) ;
delay(3000);
if (Console) Console.println("Lightman tester console");
Tlc.init(500);
delay(5000);
larray.set_light(0,0,0,2000);
//larray.set_light(12,0,0,2000);
//larray.set_curve();
larray.display_all();
delay(5000);
if (Console) Console.println("end of loop");
The sketch references this library
#include "Arduino.h"
#include "Lightman.h"
#include "Console.h"
#define LIGHTMAN_PARAMETER_COUNT 6
#define NUMBER_OF_LIGHTS 16
#define NUMBER_OF_COLOURS 3
int lights[NUMBER_OF_LIGHTS*NUMBER_OF_COLOURS][LIGHTMAN_PARAMETER_COUNT] = {0};
Lightman::Lightman()
//make an array of all the lights
//light Current_Red Current_Green Current_Blue Start_Red Start_Green Start_Blue End_Red End_Green End_Blue Cycles Curve CurveParameter
//start all brightnesses, starts, ends and Curves at 0
void Lightman::set_curve( ) //array of integers to sub into lightmants master array
if (Console) Console.println("Called set_curve");
//for each line in the parameter array
//put it in the right spot
void Lightman::set_light(int light_no, int R, int G, int B) //
if (Console) Console.println("Called set_light");
lights[light_no][0] = R;
lights[light_no][1] = G;
lights[light_no][2] = B;
void Lightman::cycle() {
int l;
int c;
for (l = 0; l<= NUMBER_OF_LIGHTS; l+=1) {
for (c=0; c<=NUMBER_OF_COLOURS; c+=1) {}
void Lightman::display_all() {
int testint1;
int testint2;
int li;
for (li = 0; li <= NUMBER_OF_LIGHTS*NUMBER_OF_COLOURS-1; li+=1) {
testint1 = li%NUMBER_OF_LIGHTS;
testint2 = li/NUMBER_OF_LIGHTS;
//if (Console) Console.println(testint1);
//if (Console) Console.println(testint2);
//if (Console) Console.println(lights[li%NUMBER_OF_LIGHTS][li/NUMBER_OF_LIGHTS]);
//if (Console) Console.println("light");
//if (Console) Console.println("Colour");
//if (Console) Console.println("Setting in 5 seconds");
delay(5000);
//Tlc.set(li,lights[li%NUMBER_OF_LIGHTS][li/NUMBER_OF_LIGHTS]);
//if (Console) Console.println("Updating in 5 seconds");
//delay(5000);
//Tlc.update();
//if (Console) Console.println("Done");
When I upload the sketch, I open the console, I am connected over Wifi to the Yun and open the consoel by selecting “serial monitor” from the tools menu. (this is required for the setup code to continue running in the test sketch) - By the way, i am a little confused by this as well - is this the console or serial monitor - I do not have the usb or lan cable plugged in, so I am assuming it is infact the console.
The console will give readouts such as
Connection closed by foreign host
or occasionally it will get further into the test sketch:
Called set_light
0
0
I have followed the advice here http://forum.arduino.cc/index.php?topic=190769.0
- replace your copy of Bridge.cpp (located at IDE_FOLDER/libraries/Bridge/src) and replace it with https://raw.githubusercontent.com/arduino/Arduino/ide-1.5.x/libraries/Bridge/src/Bridge.cpp
- Download one of the nightly builds of the IDE from http://arduino.cc/en/Main/Software. These are built every day with the latest code available on github
However the Arduino continues to dropout. Any help would be greatly appreciated.
Thanks in advance
Lawrie
