Serial Monitor breaks normal behaviour of Nano + NRF24l01
Couldn’t find any other post that mentions Serial Monitor crippling the normal workflow of the NRF24l01, so here it goes.
I have two Arduino Nano, both with NRF24l01 attached, and an RF24 library working. Both NRF24l01 have 10uF caps soldered on them. One is only sending data, another is receiving only. Both of them flash LED on, successful transmission and successful receiving respectively.
When I run both devices, i see both LEDs flashing, so one succeeds in sending, and another one in receiving. But whenever I try to open Serial Monitor in my Arduino 1.6.1 software, the LEDs flash only every forth of fifth time of expected, and in my Serial Monitor I can see only 1 of 4 or 5 packets received (though received correctly).
Any ideas what I could have done wrong? Could Serial Monitor somehow interfere with Nano talking to NRF24l01?
The code follows, it’s simple.
Sender:
 Copyright (C) 2011 J. Coliz <maniacbug@ymail.com>
 This program is free software; you can redistribute it and/or
 modify it under the terms of the GNU General Public License
 version 2 as published by the Free Software Foundation.
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
// On Successfull Sending Blink PIN
#define BLPIN 5
// Hardware configuration
// Set up nRF24L01 radio on SPI bus plus pins 9 & 10
RF24 radio(9,10);
// Topology
// Radio pipe addresses for the 2 nodes to communicate.
const uint64_t pipe = 0xF0F0F0F0E1LL;
void setup(void)
  pinMode(BLPIN, OUTPUT);
  // Print preamble
  Serial.begin(57600);
  printf_begin();
  printf("\n\rRF24/examples/GettingStarted/\n\r");
  // Setup and configure rf radio
  radio.begin();
  // optionally, increase the delay between retries & # of retries
  radio.setRetries(15,15);
  // optionally, reduce the payload size.  seems to
  // improve reliability
  radio.setPayloadSize(8);
  // Open pipes to other nodes for communication
  radio.openWritingPipe(pipe);
  // Dump the configuration of the rf unit for debugging
  radio.printDetails();
// counter data to be sent
unsigned long counter = 0;
void loop(void)
  // Increase the counter and send it
  counter++;
  printf("Sending counter = %lu...", counter);
  if (radio.write( &counter, sizeof(unsigned long) ))
    printf("ok...\n\r");
    digitalWrite(BLPIN, HIGH);
    delay(10);
    digitalWrite(BLPIN, LOW);
    printf("failed.\n\r");
  // Try again 1s later
Receiver:
#include <SPI.h>
#include "RF24.h"
#include "printf.h"
// On Receiver Blink PIN
#define BLPIN 5
RF24 radio(9,10);
// Topology
void setup(void)
  // Print preamble
  printf_begin();
  radio.begin();
  radio.openReadingPipe(1,pipe);
  // Start listening
  radio.startListening();
unsigned long counter;
void loop(void)
  // if there is data ready
  if (radio.available())
    while( radio.available() ) {
      radio.read( &counter, sizeof(unsigned long) );
      // Dump the payloads until we've gotten everything
      printf("Got payload %lu...\n\r", counter);
    delay(10);
The reason for the Monitor being unable to work properly seems to be the length of the usb cable or a faulty usb port on my computer. I had a usb-cable extender, to which another (this time short) usb cable of my Arduino Nano was attached. It seemed to work fine while I was uploading things to Nano, but a quick serial exchange was, perhaps, not possible. Another usb port, or bypassing the usb cable extender brings everything back to normal. This is a solution, while I still had no reason, how debugging through serial could influence that much on the chip behaviour itself, until now. I just thought it may well be the same power problem, as FTDI chip both powers the radio (even with the capacitor I installed!) and talks to computer through my long usb cable. If it starts talking, there could be no power for RF24 for a longer period than could be saved by my capacitor.
