SERIAL MONITOR DOES NOT RESPOND TO COMANNDS
Hello everyone,
I am reading some sensor data using arduino uno. The values appear on the serial monitor but when I insert some commands in order to enter the calibration mode it does not respond.
Do you know what could be the reason?
Thank you!
(deleted)
@benedettod
Your topic was Moved to it's current location / section as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
You may need to turn on line endings in the serial monitor.
But do take the time to read and follow the instructions in the "How to use the forum" post.
Also make sure you are entering the commands in the command box edit control, not the displayed part.
