hello my friend is using mpu6050 using the same code as mine but his seems to not show up the serial monitor. There seems to be no problem with coding because it works on mine. Can anyone give suggestions on how to fix this?
- Does the board gets detected on your device.
- Check the Port (if the device is connected)
- Is the baud rate same for device and serial monitor
Yes but we can't see your code, nether can we see your friend's code. Can you see the problem with this?
You might want to look at this How to get the best out of this forum before you proceed any further.
We only know what you tell us, and without knowing what you have, we don't stand a chance.
By the way is this an Arduino ESP32 or some other sort of ESP32?
Its not coding problem as I mentioned, which is why i didnt add the code, and it is solved simply after redownloading the Arduino. Thanks for helping though, as for your question, it is Arduino ESP32.
Checked it all, everything seems to be alright. Told him to redownload Arduino and that solved the problem! Thanks for commenting by
