Hello,
I am fairly new to Arduino, though I have done a bit of programming before. I am now taking an online class about interfacing with the Arduino and I am stuck on my latest assignment:
Write a sketch that allows a user to access data in EEPROM using the serial monitor. In the serial monitor the user should be able to type one of two commands: “read” and “write. “Read” takes one argument, an EEPROM address. “Write” takes two arguments, an EEPROM address and a value.
For example, if the user types “read 3” then the contents of EEPROM address 3 should be printed to the serial monitor. If the user types “write 3 10” then the value 10 should be written into address 3 of the EEPROM.
The EEPROM portion is easy. I have already read any memory address and written to it hard coded byte values.
My issue is that I do not seem to understand how to read a command from the Serial Monitor and use it to trigger the EEPROM portion. I have been able to get my code to read the string entered and save it in a char variable, then compare it to Read or Write to know what command was entered:
int c = 0;
int i = 0;
while (!Serial) {
Serial.println("Enter read or write option in the following format");
Serial.println("Read: Read address. Example: Read 245");
Serial.println("Write: Write address value. Example: Write 520 123");
c = Serial.available();
int c1 = 0;
int c2 = 0;
// Serial.print("Unread Bytes: ");
// Serial.println(c,DEC);
delay (500); //To allow the whole instruction be read at once
char instr[c];
if (c>0){
for (i=0;i<=c-1;i++){
instr[i] = Serial.read();
instr[c] = '\0';
Serial.print("Instruction entered: ");
Serial.print(instr[i]);
Serial.print("\n");
char comp1[] = "Read ";
char comp2[] = "Write ";
for (i=0;i<=5;i++){
if (instr[i] == comp1[i]) c1++;
else if (instr[i] == comp2[i]) c2++;
if (c1 == 5){
Serial.println("Read Command");
if (c2 == 6){
Serial.println("Write Command");
The problem I have is that the address is now in a char variable (as well as the data to be written).
I do not mean for anybody to do this for me, but suggestions will be greatly appreciated. Thanks!
Sebastian
