Hello,
I am currently building a DAQ with the following components:
1X TCA9548A Multiplexer
2X MPRLS
1X BME280
1X RTC
1X DS18B20
1X Micro SD module
2X RS232 interfaces
I have combined many of the example sketches for each sensor to get this sketch.
The Serial monitor will run only partway and freeze at the same point each time. I have tried removing some of the "Serial.print" commands in case there are just too many for the system to handle but that caused it to just freeze at a different spot.
#include <Wire.h>
#include <SPI.h>
#include <SD.h> //Used for SD card Read/Write
#include <Adafruit_Sensor.h>
#include <Adafruit_MPRLS.h> // Used for the 2 PFD pressure sensors
#include <Adafruit_BME280.h> //Temp, Humidity, Pressure Sensor
#include <DS1307RTC.h> //Used for RTC
#include <TimeLib.h> //USed for RTC
extern "C" {
#include "utility/twi.h" // from Wire library, so we can do bus scanning
#include <OneWire.h> //Used for the DS18B20 Water Temperature Sensor
#include <SoftwareSerial.h> //RS232 communication
#define TCAADDR 0x70
#define RESET_PIN -1
#define EOC_PIN -1
#define SEALEVELPRESSURE_HPA 1013.5
int RX_PIN1 = 17;
int TX_PIN1 = 16;
int RX_PIN2 = 15;
int TX_PIN2 = 14;
int count;
char serialData = "";
String dataString = "";
int data[15];
byte x;
const int chipSelect = 53;
/* Assign a unique ID to this sensor at the same time */
Adafruit_MPRLS mpr1 = Adafruit_MPRLS(RESET_PIN, EOC_PIN);
Adafruit_MPRLS mpr2 = Adafruit_MPRLS(RESET_PIN, EOC_PIN);
Adafruit_BME280 bme;
SoftwareSerial RS232_1 = SoftwareSerial(RX_PIN1, TX_PIN1);
SoftwareSerial RS232_2 = SoftwareSerial(RX_PIN2, TX_PIN2);
OneWire ds(2); // on pin 2 (a 4.7K resistor is necessary)
void tcaselect(uint8_t i) {
if (i > 7) return;
Wire.beginTransmission(TCAADDR);
Wire.write(1 << i);
Wire.endTransmission();
void setup(void)
while(!Serial);
delay (1000);
Wire.begin();
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
while (1);
Serial.println("card initialized.");
pinMode(RX_PIN1, INPUT);
pinMode(TX_PIN1, OUTPUT);
pinMode(RX_PIN2, INPUT);
pinMode(TX_PIN2, OUTPUT);
RS232_1.begin(9600);
RS232_2.begin(9600);
Serial.println("TCA Scanner Ready");
for (uint8_t t=0; t<8; t++) {
tcaselect(t);
Serial.print("TCA Port #"); Serial.println(t);
for (uint8_t addr = 0; addr<=127; addr++) {
if (addr == TCAADDR) continue;
uint8_t data;
if (! twi_writeTo(addr, &data, 0, 1, 1)) {
Serial.print("Found I2C 0x"); Serial.println(addr,HEX);
Serial.println("MPRLS Manometer Test"); Serial.println("");
/* Initialise the 1st sensor */
tcaselect(1);
if(! mpr1.begin())
Serial.println("Ooops, no MPRLS1 detected ... Check your wiring!");
while(1);
/* Initialise the 2nd sensor */
tcaselect(2);
if(!mpr2.begin())
Serial.println("Ooops, no MPRLS2 detected ... Check your wiring!");
while(1);
void loop(void)
/* Get a new MPRLS Pressure event */
sensors_event_t event;
tmElements_t tm;
tcaselect(0);
if (RTC.read(tm)) {
Serial.print("Time ");
dataString += "Time ";
print2digits(tm.Hour);
Serial.write(':');
dataString += ":";
print2digits(tm.Minute);
Serial.write(':');
dataString += ":";
print2digits(tm.Second);
Serial.print(", Date (D/M/Y) = ");
dataString += ", Date (D/M/Y) = ";
Serial.print(tm.Day);
Serial.write('/');
dataString += "/";
Serial.print(tm.Month);
Serial.write('/');
dataString += "/";
Serial.print(tmYearToCalendar(tm.Year));
dataString += String(tmYearToCalendar(tm.Year));
dataString += " ";
else {
if (RTC.chipPresent()) {
Serial.println("The DS1307 is stopped. Please run the SetTime");
Serial.println("example to initialize the time and begin running.");
Serial.println("DS1307 read error! Please check the circuitry.");
delay(9000);
tcaselect(1);
/* Display the results (magnetic vector values are in micro-Tesla (uT)) */
Serial.print("Sensor #1 - ");
Serial.print("Pressure (PSI): "); Serial.print(mpr1.readPressure()/68.947572932); Serial.print(" ");
dataString += "Pressure 1 (PSI): ";
dataString += String(mpr1.readPressure()/68.947572932);
tcaselect(2);
Serial.print("Sensor #2 - ");
Serial.print("Pressure (PSI): "); Serial.print(mpr2.readPressure()/68.947572932); Serial.print(" ");
Serial.println(" ");
dataString += " Pressure 2 (PSI): ";
dataString += String(mpr2.readPressure()/68.947572932);
tcaselect(7);
printBMEValues();
printWaterTemp();
printRS232();
delay(2000);
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port:
Serial.println(dataString);
// if the file isn't open, error:
else {
Serial.println("error opening datalog.txt");
Serial.println("done");
void printBMEValues ()
Serial.print("Air Temperature: ");
dataString += "Air Temperature: ";
Serial.print(bme.readTemperature());
dataString += String(bme.readTemperature());
Serial.println(" *C");
dataString += " *C";
Serial.print(" Air Pressure: ");
dataString += " Air Pressure: ";
Serial.print(bme.readPressure() / 100.0F);
dataString += String(bme.readPressure() / 100.0F);
Serial.println(" hPa");
dataString += " hPa";
Serial.print(" Humidity: ");
dataString += " Humdity: ";
Serial.print(bme.readHumidity());
dataString += String(bme.readHumidity());
Serial.println(" %");
dataString += " %";
dataString += " ";
void print2digits(int number) {
if (number >= 0 && number < 10) {
Serial.write('0');
dataString += "0";
Serial.print(number);
dataString += String(number);
void printWaterTemp (){
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println("No more addresses.");
ds.reset_search();
delay(250);
return;
ds.reset();
ds.select(addr);
ds.write(0x44, 1);
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for ( i = 0; i < 9; i++) {
data[i] = ds.read();
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3;
if (data[7] == 0x10) {
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
if (cfg == 0x00) raw = raw & ~7;
else if (cfg == 0x20) raw = raw & ~3;
else if (cfg == 0x40) raw = raw & ~1;
celsius = (float)raw / 16.0;
fahrenheit = celsius * 1.8 + 32.0;
Serial.print("Water Temperature: ");
dataString += "Water Temperature: ";
Serial.print(celsius);
dataString += String(celsius);
Serial.print(" *C");
ds.reset_search();
/* Function to read incoming data from the RS232 connected to the Load cell */
void printRS232 ()
count = 0;
if (RS232_1.available()) {
dataString += "Load Cell 1: ";
Serial.print("Load Cell 1: ");
while (count < 15){
x = RS232_1.read();
Serial.write(x);
dataString += String(x);
Serial.print(" , ");
data[count] = x;
delay;
count++;
for(count = 0;count<15;count++){
Serial.print(data[count]);
Serial.print(",");
count = 0;
dataString += " Load Cell 2: ";
Serial.print(" Load Cell 2: ");
if (RS232_2.available()) {
while (count < 15)
x = RS232_2.read();
Serial.write(x);
data[count] = x;
delay;
count++;
Serial.print(",");
