Serial Monitor: garbish in output
Hi Arduino Geeks,
Each time I open the serial monitor I get some "garbish characters" displayed ...
void setup() { Serial.begin(9600); Serial.print("Controller up and running."); Serial.print("\n"); inputString.reserve(254); }
The output looks like this ... @h½¹up and running. Setup 0: all off
@h½¹Ñɽ±±?Ɂup and running. Setup 0: all off
Anny hints how to prevent this ...?
thx Alexander
Which Arduino are you using?
sorry for not mentioning: Arduino Mega 2560
Are there differences in serial behavior?
thx Alexander
You haven't posted all of your code.
I wonder if inputString.reserve(254); is corrupting something?
I guess you are using Strings (large S) which often cause problems in the limited memory of an Arduino. The general advice is to use strings (small s).
...R
ademmler: Hi,
thx Alexander
Not that one. I don't have a Leonardo but I recall some wait-around with serial for those.
Another thing to check is serial monitor has the same speed (baud rate).
I sometimes get some screen trash on starting serial monitor but I can't remember any fix. It usually precedes what my program sends. So yes, I am interested too!
Hello robin2,
thx for your hints. From your post:
I wonder if inputString.reserve(254); is corrupting something? I removed this option - the effect was the same. I use it because I use Serial Event: http://arduino.cc/en/Tutorial/SerialEvent
This I do not understand at all ... sorry. What does it mean. Greetings Alexander
Hi folks,
I found a solution by myself. This did the trick: //Setup Serial input and reserve 200 bytes for the inputString: Serial.begin(9600); inputString.reserve(200);
Serial.read(); inputString = "";
I have placed it at the top of setup. Alexander
Nonsense. The two are completely unrelated.
The advice to quit relying on the poorly implemented String class was sound. Heed it or you will see more problems.
