Serial Monitor Gives data but adds random letters to the mix
#include <math.h>
#define led 3          // the PWM pin the LED is attached to
int full = 255;
double T1 = 293.00; //Temperature Recorded in Kelvin 20C
double T2 = 303.00; //30 C
double T3 = 313.00; //40 C
double R1 = 12470.00;
double R2 = 8416.00;
double R3 = 2972.00;
double L1 = log (R1); //Is actually a ln but this give right values
double L2 = log (R2);
double L3 = log (R3);
double Y1 = 1 / T1;
double Y2 = 1 / T2;
double Y3 = 1 / T3;
double X2 = (Y2 - Y1) / (L2 - L1);
double X3 = (Y3 - Y1) / (L3 - L1);
double C = ((X3 - X2) / (L3 - L2)) * pow ((L1 + L2 + L3), -1);
double B = X2 - C * (L1 * L1 + L1 * L2 + L2*L2);
double A = Y1 - L1 * (B + C*L1*L1);
double temperature43(double Ana) { // Function to convert analog from arduino into temperature values for plot
  double temp, VI, Vo, V, r1, r2, b, c, lr2, f;
  r1 = 43000; // Resistor of 43K ohms
  VI = 5;
  Vo = Ana * 5 / 1023;
  V = VI / Vo ;
  r2 = r1 * (V - 1);
  b = B * log(r2);
  lr2 = log(r2);
  c = C * pow (lr2, 3);
  f = A + b + c;
  temp = 1 / f;
  temp = temp - 273; //into celcius
  temp = temp * 9 / 5 + 32; // into farenheight
  return temp;
double temperature75(double Ana) { // Function to convert analog from arduino into temperature values for plot
  r1 = 75000; // Resistor of 43K ohms
  VI = 5;
  V = VI / Vo ;
  r2 = r1 * (V - 1);
  b = B * log(r2);
  lr2 = log(r2);
  f = A + b + c;
  temp = 1 / f;
  return temp;
void setup () {
  pinMode(led, OUTPUT);
  analogWrite(led, full);
  double val1, val2, val3, val4, val5, val6, temp1, temp2, temp3, temp4, temp5, temp6;
  val1 = analogRead(0); //43K
  val2 = analogRead(1); //43K
  val3 = analogRead(2); //75K
  val4 = analogRead(3); //75K
  val5 = analogRead(4); //75K
  val6 = analogRead(5); //75K
  temp1 = temperature43(val1); //for board with 43K resitor
  temp2 = temperature43(val2); //for board with 43K resitor
  temp3 = temperature75(val3); //for board with 75K resitor
  temp4 = temperature75(val4); //for board with 75K resitor
  temp5 = temperature75(val5); //for board with 75K resitor
  temp6 = temperature75(val6); //for board with 75K resitor
  Serial.println(temp1);
  Serial.println(temp2);
  Serial.println(temp3);
  Serial.println(temp4);
  Serial.println(temp5);
  Serial.println(temp6);
When I run my code it prints the correct values for the temperature most of the time but every once in a while it will print 77.12 as 7rj or something like that. I will attach a screenshot of the serial monitor. Both my Arduino Uno and the Online Monitor are at 115200 baud. I am running Windows 7.
Here is the screen shot of my monitor
The serial Baud rate is probably off slightly. On the standard Arduino, the clock (resonator) is not very accurate.
The problem may go away if you choose a lower Baud rate, so try dropping it in steps, choosing among the allowed possibilities.
If that doesn't fix it, use an Arduino with a genuine crystal as the CPU clock.
When I dropped the Baud rate it worked. Thanks for the help!
