Serial Monitor Help
So I found this code online to run an electric skateboard remote. I don’t fully understand all the componets, but had it working at one point. I added a serial print at the end to check if my remote was connected and actually transmitting to the other arduino. That was working too, but recently it doesn’t seem to be working right. I have it outputting 2 numbers, the direct reading from the remote, and the translated number for the ESC. And instead of continusly outputting values, it outputs one for each (0 and 9) then stops. Any ideas to fix would be greatly appreaticed!
Patrick
#include <nRF24L01.h>
#include <printf.h>
#include <RF24.h>
#include <RF24_config.h>
#include <Servo.h>
//Settings
#define DEADZONECRUISE 10
#define SENSIBILITYDIV 35
#define ACCELERATIONDELAY 400
#define BEGINNERDIV 2
#define MOTORIDLE 90
#define TIMEOUTDELAY 500
#define COLORCHANGESPEED 3
#define STILLCOLOR 2000
#define STILLCOLORCRAZY 300
#define BUTTONDELAY 400
//Pins
short RF24cePin = 7;
short RF24csnPin = 8;
short motorPin = 9;
short redPin = 3;
short greenPin = 5;
short bluePin = 6;
#define MOTOR 0
#define HORIZONTAL 1
#define CBUTTON 3
#define ZBUTTON 2
//Leds
int stillColor = STILLCOLOR;
int colorChangeSpeed = COLORCHANGESPEED;
int newBlue = 0;
int newRed = 0;
int newGreen = 0;
int blueValue = 0;
int greenValue = 0;
int redValue = 0;
short color = 0;
//Initialisations
bool hold = false;
bool discoMode = false;
bool crazyColor = false;
bool beginnerMode = false;
bool brakeAllowed = true;
bool lastCButtonState = false;
bool lastZButtonState = false;
int lastHorizontalValue = 50;
long lastRead;
long lastColorChange;
long lastColorDisco;
long lastAcceleration;
int msg[4];
Servo motor;
RF24 radio(RF24cePin, RF24csnPin);
//const uint64_t pipe = 0xE8E8F0F0E1LL;//White nunchuck
const uint64_t pipe = 0xE8E8F0F1E0LL;//Aymeric
void setColor() {
  switch (color) {
    case 0:
      newBlue = 255;
      newGreen = 0;
      newRed = 0;
    case 1:
      newBlue = 0;
      newGreen = 255;
      newRed = 0;
    case 2:
      newBlue = 0;
      newGreen = 0;
      newRed = 255;
    case 3:
      newBlue = 255;
      newGreen = 255;
      newRed = 0;
    case 4:
      newBlue = 0;
      newGreen = 255;
      newRed = 255;
    case 5:
      newBlue = 255;
      newGreen = 0;
      newRed = 255;
    case 6:
      newBlue = 255;
      newGreen = 255;
      newRed = 255;
    case 7:
      newBlue = 0;
      newGreen = 0;
      newRed = 0;
void refreshLed() {
  if (millis() - lastColorChange > colorChangeSpeed) {
    lastColorChange = millis();
    if (blueValue > newBlue) {
      blueValue--;
    } else if ( blueValue < newBlue) {
      blueValue++;
    if (greenValue > newGreen) {
      greenValue--;
    } else if (greenValue < newGreen) {
      greenValue++;
    if (redValue > newRed) {
      redValue--;
    } else if (redValue < newRed) {
      redValue++;
  if (discoMode && (millis() - lastColorDisco) > stillColor) {
    lastColorDisco = millis();
    if (color >= 6) color = 0;
    else color++;
    setColor();
  analogWrite(bluePin, blueValue);
  analogWrite(greenPin, greenValue);
  analogWrite(redPin, redValue);
void ledButtonPressed() {
  if (discoMode && !crazyColor) { //Turn led off
    discoMode = false;
    color = 7;
    setColor();
    redValue = 0;
    blueValue = 0;
    greenValue = 0;
    discoMode = true;
    crazyColor = !crazyColor;
    if (crazyColor) {
      stillColor = STILLCOLORCRAZY;
      colorChangeSpeed = 0;
void sendMotor(int value) {
  if (value >= 89 && !beginnerMode) motor.write(value);
  else if (value >= 89 && value <= (90 + 90 / BEGINNERDIV)) motor.write(value);
  else if (value >= (90 + 90 / BEGINNERDIV)) motor.write((90 + 90 / BEGINNERDIV));
  else if (value < 89 && brakeAllowed) motor.write(value);
  else motor.write(MOTORIDLE);
void getData() {
  if (millis() - lastRead > TIMEOUTDELAY) { // Let go if signal timeout
    sendMotor(MOTORIDLE);
    brakeAllowed = false;
  if (radio.available()) {
    while (radio.available()) radio.read(msg, 7); //Get data
    if (msg[MOTOR] >= 89) brakeAllowed = true;
    if (!msg[CBUTTON] && lastCButtonState && !msg[ZBUTTON]) ledButtonPressed();
    if (!msg[ZBUTTON] && lastZButtonState) Serial.write(2);
    if (msg[ZBUTTON] && !beginnerMode) sendMotor(msg[MOTOR]);
    else if (msg[ZBUTTON] && beginnerMode) {
      if (msg[MOTOR] >= 89) sendMotor(map(msg[MOTOR], 0, 180, (90 -30 -60 / BEGINNERDIV), (90 +30+ 60 / BEGINNERDIV)));
      else sendMotor(msg[MOTOR]);
    else if (!msg[ZBUTTON] && motor.read() >= 89) { //If zbutton and not braking
      if (msg[MOTOR] < (180 - DEADZONECRUISE) / 2 && (motor.read() - ((180 - DEADZONECRUISE) / 2 - msg[MOTOR]) / SENSIBILITYDIV) >= 89 && lastAcceleration - millis() > ACCELERATIONDELAY) { //if doesnt not imply brakes
        sendMotor(motor.read() - ((180 - DEADZONECRUISE) / 2 - msg[MOTOR]) / SENSIBILITYDIV); //reduce speed
        lastAcceleration = millis();
      } else if (msg[MOTOR] <= (180 + DEADZONECRUISE) / 2 && lastAcceleration - millis() > ACCELERATIONDELAY) { //If in deadzone
        sendMotor(motor.read());
        if (msg[HORIZONTAL] >= 95) beginnerMode = true;
        else if (msg[HORIZONTAL] <= 5) beginnerMode = false;
      } else if (lastAcceleration - millis() > ACCELERATIONDELAY) {
        sendMotor(motor.read() + (msg[MOTOR] - (180 + DEADZONECRUISE) / 2) / SENSIBILITYDIV);
    if (msg[ZBUTTON] && msg[HORIZONTAL] >= 80 && lastHorizontalValue < 95) Serial.write(2);
    else if (msg[ZBUTTON] && msg[HORIZONTAL] <= 20 && lastHorizontalValue > 5) Serial.write(1);
    lastZButtonState = msg[ZBUTTON];
    lastCButtonState = msg[CBUTTON];
    lastHorizontalValue = msg[HORIZONTAL];
    lastRead = millis();
  motor.attach(motorPin);
  radio.begin();
  radio.openReadingPipe(1, pipe);
  radio.startListening();
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  Serial.println(msg[HORIZONTAL]);
   Serial.println(motorPin);
  getData();
  refreshLed();
I recommend adding more Serial.println() statements at strategic points in the code so you can see what's happening by watching the Serial Monitor while the program runs.
Yes will do thanks for the suggestion.
Why on earth are you using a while statement here?
Why are you reading 7 bytes into a 4 element int array? Can you not multiply by 2?
When you have problems with radios, posting one side of the conversation makes it impossible to help you.
I agree with @PaulS. There is no need for while(radio.available ...). An nRF24 shows available when the full message has been received. It is not like a Serial connection which receives messages one byte at a time.
Have a look at the examples in this Simple nRF24L01+ Tutorial
...R
