Serial Monitor Horizontal
Hi, I have a small problem here.
When I program the Arduino to send data to the serial monitor is does so in a horizontal matter. (see the picture), here is the code I’m using:
#include <Servo.h>
int vals = 0;
Servo servox;
Servo servoy;
  servox.attach(2);
  servoy.attach(3);
      if (Serial.available())
   vals = Serial.read();
   if(vals == 99)
        servox.write(85);
        servoy.write(83);
       Serial.print("CENTER");
     if(vals == 119)
        servox.write(4);
       Serial.print("UP");
   if(vals == 115)
        Serial.print("DOWN");
        servox.write(140);
      if(vals == 97)
        Serial.print("LEFT");
        servoy.write(20);
           if(vals == 100)
        Serial.print("RIGHT");
        servoy.write(160);
This is what I get:
So how do I get the Arduino to send it line for line?
Thanks in Advance!
Serial.println
  if(vals == 'c')
        servox.write(85);
        servoy.write(83);
     if(vals == 'w')
is probably easier to read.
Dude your awesome.
Instead of using Serial.print("CENTER");
try using Serial.println("CENTER");
This will add a carrage return/line feed to the end of the string so it will go to a new line.
