Serial monitor in IDE 2.x.x printing garbage after several time
I Wrote some code to clear the EEPROM chip data and then write the data into it and read data from the chip.
this is my code:
#define SHIFT_DATA 2
#define SHIFT_CLK 3
#define SHIFT_LATCH 4
#define EEPROM_D0 5
#define EEPROM_D7 12
#define WRITE_EN 13
 * Output the address bits and outputEnable signal using shift registers.
void setAddress(int address, bool outputEnable) {
  shiftOut(SHIFT_DATA, SHIFT_CLK, MSBFIRST, (address >> 8) | (outputEnable ? 0x00 : 0x80));
  shiftOut(SHIFT_DATA, SHIFT_CLK, MSBFIRST, address);
  digitalWrite(SHIFT_LATCH, LOW);
  digitalWrite(SHIFT_LATCH, HIGH);
 * Read a byte from the EEPROM at the specified address.
byte readEEPROM(int address) {
  for (int pin = EEPROM_D0; pin <= EEPROM_D7; pin += 1) {
    pinMode(pin, INPUT);
  setAddress(address, /*outputEnable*/ true);
  byte data = 0;
  for (int pin = EEPROM_D7; pin >= EEPROM_D0; pin -= 1) {
    data = (data << 1) + digitalRead(pin);
  return data;
 * Write a byte to the EEPROM at the specified address.
void writeEEPROM(int address, byte data) {
  setAddress(address, /*outputEnable*/ false);
    pinMode(pin, OUTPUT);
    digitalWrite(pin, data & 1);
    data = data >> 1;
  digitalWrite(WRITE_EN, LOW);
  delayMicroseconds(1);
  digitalWrite(WRITE_EN, HIGH);
  delay(10);
 * Read the contents of the EEPROM and print them to the serial monitor.
void printContents() {
  for (int base = 0; base <= 255; base += 16) {
    byte data[16];
    for (int offset = 0; offset <= 15; offset += 1) {
      data[offset] = readEEPROM(base + offset);
    char buf[80];
    sprintf(buf, "%03x:  %02x %02x %02x %02x %02x %02x %02x %02x   %02x %02x %02x %02x %02x %02x %02x %02x",
            base, data[0], data[1], data[2], data[3], data[4], data[5], data[6], data[7],
            data[8], data[9], data[10], data[11], data[12], data[13], data[14], data[15]);
    Serial.println(buf);
// 4-bit hex decoder for common anode 7-segment display
byte data[] = { 0x81, 0xcf, 0x92, 0x86, 0xcc, 0xa4, 0xa0, 0x8f, 0x80, 0x84, 0x88, 0xe0, 0xb1, 0xc2, 0xb0, 0xb8 };
// 4-bit hex decoder for common cathode 7-segment display
// byte data[] = { 0x7e, 0x30, 0x6d, 0x79, 0x33, 0x5b, 0x5f, 0x70, 0x7f, 0x7b, 0x77, 0x1f, 0x4e, 0x3d, 0x4f, 0x47 };
  //Put your setup code here, to run once:
  pinMode(SHIFT_DATA, OUTPUT);
  pinMode(SHIFT_CLK, OUTPUT);
  pinMode(SHIFT_LATCH, OUTPUT);
  pinMode(WRITE_EN, OUTPUT);
  Serial.begin(57600);
  // Erase the entire EEPROM
  Serial.print("Erasing EEPROM");
  for (int address = 0; address <= 2047; address += 1) {
    writeEEPROM(address, 0xff);
    if (address % 64 == 0) {
      Serial.print(".");
  Serial.println(" done");
  // Program data bytes
  Serial.print("Programming EEPROM");
  for (int address = 0; address < sizeof(data); address += 1) {
    writeEEPROM(address, data[address]);
      Serial.print(".");
  // Read and print out the contents of the EERPROM
  Serial.println("Reading EEPROM");
  printContents();
when I upload the code in Arduino, seems like clearing, writing, and reading are doing well but when I open the serial monitor it shows me garbage after several bytes...
I don't see any solution.
how can I solve that?
here is my output:
Erasing EEPROM................................ done
Programming EEPROM. done
Reading EEPROM
000:  81 cf 92 86 cc a4 a0 8f   80b84b8"%r(f1(G"%r(f1(G"010:  ff0gf(ff fv!fn ff vg nf   vg nf fd ff ff ff ff ff
020:  ff ff ff ff ff ff ff ff   ff ff ff ff ff ff ff ff
030:  ff ff ff ff ff ff ff ff   ff ff ff ff ff ff ff ff
040:  ff ff ff ff ff ff ff ff   ff ff ff ff ff ff ff ff
050:& ff ff &f ff fd&f ff fd&`  ff ff fG ff &f Gf fd fb
0&p:d gn0fb ff ff ff ff ff ff   ff ff ff ff ff ff ff ff
070:  ff ff ff ff ff ff ff ff   ff ff ff ff ff ff ff ff
080:  ff ff ff ff ff ff ff ff   ff ff ff ff ff ff ff ff
090:  ff ff ff ff ff ff ff ff   "f ff fF ff ff f ff ff f
0g0>  fn0gf(ff fv!fn f` vg nf   vg nf ff ff ff ff ff ff
0b0:  ff ff ff ff ff ff ff ff   ff ff ff ff ff ff ff ff
0c0:  ff ff ff ff ff ff ff ff   ff ff ff ff ff ff ff ff
0d0:  ff ff ff ff ff ff ff ff   ff ff ff ff ff ff ff ff
0e0:  foff0ff oF f0ff oF f6f  )Ff 6f fofd0ff oF fv fb
0f0:$ of0ff ff ff ff ff ff ff   ff ff ff ff ff ff ff ff
in the first line and first column, we see the right data that we write in the chip
but other bits are garbage...
I don't know why...
Which EEPROM? what's your wiring?
is it OK to have a fast pulse on the latch?
seems also you get weird printout, so I'd double check the sprintf
(calling everything data and relying on scope is not great for readability of the code )
my EEPROM is AT28C16
and in the source video, all is ok and no problem...
but in my system with the same code, show this garbage on the serial monitor
also in the source video tutorial, the IDE is 1.x.x
I found the solution...
my board is Arduino NANO
On the Arduino web page, it says to me to set the baud rate for this board to 9600, but I set the baud rate to 1200 and it works fine.
I don't know why 9600 not working, maybe for my cable or my usb port.
anyway, it works fine.
Maybe try TeraTerm (or PuTTY).
A nano supports much higher baud rate… 9600 should be piece of cake to handle …
It actually does not make much sense because your first bit of data was correct if I'm not mistaken.
You more than likely have a clone. I seem to remember that this can happen with a board based on a LGT8fx chip instead of an Atmel 328P.
Can you post some clear pictures of your board where the print on the chips is readable?
