serial monitor input
hi, i am using the icomsat v1.1 GSM module, and want to send an SMS through serial input. so after typing in serial monitor and hitting enter, it will send. i want to modify the sketch so that i can change the content of what i want to send.
if (sms.SendSMS("+6148123123123", "SMS from Arduino"))
so basically, when start, the GSM will send the "SMS from Arduino to "+6148123123123". is there a way i can change the "SMS from Arduino" to what ever i type in the serial monitor?
this is the full sketch
#include "SIM900.h"
#include <SoftwareSerial.h>
#include "sms.h"
SMSGSM sms;
boolean started=false;
  //Serial connection.
  Serial.println("GSM Shield testing.");
  if (gsm.begin(2400)){
    Serial.println("\nstatus=READY");
    started=true;
  else Serial.println("\nstatus=IDLE");
  if(started){
      Serial.println("\nSMS sent OK");
thanks for your help, i feel so useless when it comes to programming.....
Input through serial monitor using Serial.read() only reads the first character....you need to extract each of these characters, then form a string out of it. Then send this string as an SMS
cant i use some thing like Serial.read(n)?
and then maybe something like if (sms.SendSMS("+6148123123123", n)) ?
this is a different sketch but similar function
/* GSM Shield example
 created 2011
 by Boris Landoni
 This example code is in the public domain.
 http://www.open-electronics.org
 http://www.futurashop.it
#include <GSM_Shield.h>
char number[]="+39123456789";  //Destination number
char text[]="hello world";  //SMS to send
byte type_sms=SMS_UNREAD;      //Type of SMS
byte del_sms=0;                //0: No deleting sms - 1: Deleting SMS
GSM gsm;
char sms_rx[122]; //Received text SMS
//int inByte=0;    //Number of byte received on serial port
char number_incoming[20];
int call;
int error;
  Serial.println("system startup");
  gsm.TurnOn(9600);          //module power on
  gsm.InitParam(PARAM_SET_1);//configure the module
  gsm.Echo(0);               //enable AT echo
  char inSerial[5];
  int i=0;
  delay(2000);
    Check_Call(); //Check if there is an incoming call
    Check_SMS();  //Check if there is SMS
    //Check data serial com
    if (Serial.available() > 0)
       while (Serial.available() > 0) {
         inSerial[i]=(Serial.read()); //read data
         i++;
       inSerial[i]='\0';
      Check_Protocol(inSerial);
void Check_Protocol(String inStr)
       Serial.print("Command: ");
       Serial.println(inStr);
  Serial.println("Check_Protocol");
    switch (inStr[0])
       case 'a' :  //Answer
           if (gsm.CallStatus()==CALL_INCOM_VOICE){
             gsm.PickUp();
             Serial.println("Answer");
             Serial.println("No incoming call");
       case 'c': // C  //Call
         if (inStr.length()<2)  //To call variable 'number'    comand   c
           Serial.print("Calling ");
           Serial.println(number);
           gsm.Call(number);
         if (inStr.length()==2)  //To call number in phone book position   comand   cx where x is the SIM position
             error=gsm.GetPhoneNumber(inStr[1],number);
             if (error!=0)
               gsm.Call(number);
               Serial.print("No number in pos ");
               Serial.println(inStr[1]);
       case 'h': //H //HangUp if there is an incoming call
         if (gsm.CallStatus()!=CALL_NONE)
           Serial.println("Hang");
           gsm.HangUp();
       case 's': //S //Send SMS
         Serial.print("Send SMS to ");
         error=gsm.SendSMS(number,text);
         if (error==0)  //Check status
             Serial.println("SMS ERROR \n");
             Serial.println("SMS OK \n");
       case 'p':  //Read-Write Phone Book
         if (inStr.length()==3)
           switch (inStr[1])
             case 'd':  //Delete number in specified position  pd2
               error=gsm.DelPhoneNumber(inStr[2]);
               if (error!=0)
                 Serial.print("Phone number position ");
                 Serial.print(inStr[2]);
                 Serial.println(" deleted");
             case 'g':  //Read from Phone Book position      pg2
               error=gsm.GetPhoneNumber(inStr[2],number);
               if (error!=0)  //Find number in specified position
                 Serial.print("Phone Book position ");
                 Serial.print(": ");
               else  //Not find number in specified position
                 Serial.print("No Phone number in position ");
                 Serial.println(inStr[2]);
             case 'w':  //Write from Phone Book Position    pw2
               error=gsm.WritePhoneNumber(inStr[2],number);
               if (error!=0)
                 Serial.print("Number ");
                 Serial.print(number);
                 Serial.print(" writed in Phone Book position ");
               else Serial.println("Writing error");
    delay(1500);
    return;
 void Check_Call()  //Check status call if this is available
     call=gsm.CallStatus();
     switch (call)
       case CALL_NONE:
         Serial.println("no call");
       case CALL_INCOM_VOICE:
         gsm.CallStatusWithAuth(number_incoming,0,0);
         Serial.print("incoming voice call from ");
         Serial.println(number_incoming);
       case CALL_ACTIVE_VOICE:
         Serial.println("active voice call");
       case CALL_NO_RESPONSE:
         Serial.println("no response");
     return;
 void Check_SMS()  //Check if there is an sms 'type_sms'
     char pos_sms_rx;  //Received SMS position
     pos_sms_rx=gsm.IsSMSPresent(type_sms);
     if (pos_sms_rx!=0)
       //Read text/number/position of sms
       gsm.GetSMS(pos_sms_rx,number_incoming,sms_rx,120);
       Serial.print("Received SMS from ");
       Serial.print(number_incoming);
       Serial.print("(sim position: ");
       Serial.print(word(pos_sms_rx));
       Serial.println(")");
       Serial.println(sms_rx);
       if (del_sms==1)  //If 'del_sms' is 1, i delete sms
         error=gsm.DeleteSMS(pos_sms_rx);
         if (error==1)Serial.println("SMS deleted");
         else Serial.println("SMS not deleted");
     return;
         error=gsm.SendSMS(number,[i][b]text[/b][/i]);
[i][b]char text[]="hello world";[/b][/i]  //SMS to send
byte del_sms=0;
isnt there a way to change the char text at will from the serial display?
Simple code that will collect characters sent from the serial monitor until a comma , is received, then the received String is sent back to the serial monitor.
//zoomkat 3-5-12 simple delimited ',' string parce
//from serial port input (via serial monitor)
//and print result out serial port
// CR/LF could also be a delimiter
String readString;
  Serial.println("serial delimit test 1.0"); // so I can keep track of what is loaded
  //expect a string like wer,qwe rty,123 456,hyre kjhg,
  //or like hello world,who are you?,bye!,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      //do stuff
      Serial.println(readString); //prints string to serial port out
      readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
hello, thanks for the reply, is my logic correct for the sketch? it cannot compile for now but would it work?
 created 2011
 by Boris Landoni
String readString;
[i][b]char text[]= c ;  //SMS to send[/b][/i]
GSM gsm;
int call;
int error;
[i][b]  if (Serial.available())  {
    if (c == ',') {
      //do stuff
    else {
      readString += c; //makes the string readString[/b][/i]
  char inSerial[5];
  int i=0;
  delay(2000);
         i++;
       inSerial[i]='\0';
    switch (inStr[0])
         [i][b]error=gsm.SendSMS(number,text);  [/b][/i]
    delay(1500);
    return;
     if (pos_sms_rx!=0)
     return;
No, that certainly will not compile
sorry, maybe i shouldnt try and bold it
 created 2011
 by Boris Landoni
String readString;
char text[]=Serial.read();  //SMS to send
GSM gsm;
int call;
int error;
    if (c == ',') {
      //do stuff
    else {
  char inSerial[5];
  int i=0;
  delay(2000);
         i++;
       inSerial[i]='\0';
    switch (inStr[0])
    delay(1500);
    return;
     switch (call)
       case CALL_NONE:
     return;
     if (pos_sms_rx!=0)
     return;
i need to modify this line so that i can change the sms content..... if i put char text[]="hello"; then "hello" will be sent. i want to use the serial monitor to change that text
sorry for my frequent post, i need to solve it ASAP. this sketch can compile, but i cant send the sms and before i type in the serial monitor, it says SMS sent.
#include "SIM900.h"
//If not used, is better to exclude the HTTP library,
//for RAM saving.
//If your sketch reboots itself proprably you have finished,
//your memory available.
//#include "inetGSM.h"
//If you want to use the Arduino functions to manage SMS, uncomment the lines below.
#include "sms.h"
SMSGSM sms;
String readString;
//To change pins for Software Serial, use the two lines in GSM.cpp.
//GSM Shield for Arduino
//this code is based on the example of Arduino Labs.
//Simple sketch to send and receive SMS.
int numdata;
char smsbuffer[160];
char n[20];
    if (c == ',') {
      //do stuff
         int n = readString.toInt();
    else {
  //Start configuration of shield with baudrate.
  //For http uses is raccomanded to use 4800 or slower.
    started=true;
  if(started){
    //Enable this two lines if you want to send an SMS.
    if (sms.SendSMS("+XXXXXXX" , n))
really need some help...thanks
You either need to learn to type faster, or don't send anything until you got everything you want to send.
How do you know when the message you're entering is complete?
cant i use the "," function? only if i put a "," it will send..
