I have an example program which runs perfect but when interacting with it thru the serial monitor I am having issues. The program asks the user for input, then displays it, and tell you if your answer is right or wrong. Very simple, but when I send a value thru the serial monitor, like 15, it says that I inputted 34 when I actually inputted 15. It very random, and it never yields the number i input. How do I fix this? I thought it was my computer but I tried on a different one and had the same issue. Also used an arduino nano, no difference. I am not sure it is the code or not either? Like i said its an example code from a books file library.
// Project 17 - Making a Binary Quiz Game
#define DATA 6 // connect to pin 14 on the 74HC595
#define LATCH 8 // connect to pin 12 on the 74HC595
#define CLOCK 10 // connect to pin 11 on the 74HC595
int number = 0;
int answer = 0;
pinMode(LATCH, OUTPUT); // set up the 74HC595 pins
pinMode(CLOCK, OUTPUT);
pinMode(DATA, OUTPUT);
randomSeed(analogRead(0)); // initialize the random number generator
displayNumber(0); // clear the LEDs
void displayNumber(byte a)
// sends byte to be displayed on the LEDs
digitalWrite(LATCH, LOW);
shiftOut(DATA, CLOCK, MSBFIRST, a);
digitalWrite(LATCH, HIGH);
void getAnswer()
// receive the answer from the player
int z = 0;
Serial.flush();
while (Serial.available() == 0)
// do nothing until something comes into the serial buffer
// one character of serial data is available, begin calculating
while (Serial.available() > 0)
// move any previous digit to the next column on the left; in
// other words, 1 becomes 10 while there is data in the buffer
answer = answer * 10;
// read the next number in the buffer and subtract the character '0'
// from it to convert it to the actual integer number
z = Serial.read() - '0';
// add this digit into the accumulating value
answer = answer + z;
// allow a short delay for any more numbers to come into Serial.available
delay(5);
Serial.print("You entered: ");
Serial.println(answer);
void checkAnswer()
//check the answer from the player and show the results
if (answer == number) // Correct!
Serial.print("Correct! ");
Serial.print(answer, BIN);
Serial.print(" equals ");
Serial.println(number);
else // Incorrect
Serial.print("Incorrect, ");
Serial.print(number, BIN);
answer = 0;
delay(10000); // give the player time to review his or her answers
number = random(256);
displayNumber(number);
Serial.println("What is the binary number in base-10? ");
getAnswer();
checkAnswer();
