Serial monitor is not displaying any values in wokwi
This is my code for seeing the values of the mpu6050 sensor on the serial monitor but it isn't being displayed. Please, someone, help
#include <Wire.h>
long accelX, accelY, accelZ;
float gForceX, gForceY, gForceZ;
long gyroX, gyroY, gyroZ;
float rotX, rotY, rotZ;
  Serial.println("Welcome to the Serial Monitor!");
  Wire.begin();
  setupMPU();
void setupMPU(){
  Wire.beginTransmission(0b1101000);
  Wire.write(0x6B);
  Wire.write(0b00000000);
  Wire.endTransmission();
  Wire.write(0x1B);
  Wire.write(00000000);
  Wire.write(0x1C);
void recordAccelRegisters(){
  Wire.write(0x3B);
  Wire.requestFrom(0b1101000,6);
  while(Wire.available() < 6);
  accelX = Wire.read()<<8|Wire.read();
  accelY = Wire.read()<<8|Wire.read();
  accelZ = Wire.read()<<8|Wire.read();
  processAccelData();
void processAccelData(){
  gForceX = accelX / 16384.0;
  gForceY = accelY / 16384.0;
  gForceZ = accelZ / 16384.0;
void recordGyroRegisters(){
  Wire.write(0x43);
  gyroX = Wire.read()<<8|Wire.read();
  gyroY = Wire.read()<<8|Wire.read();
  gyroZ = Wire.read()<<8|Wire.read();
  processGyroData();
void processGyroData(){
  rotX = gyroX / 131.0;
  rotY = gyroY / 131.0;
  rotZ = gyroZ / 131.0;
void printData() {
  Serial.print("Gyro (deg)");
  Serial.print(" X=");
  Serial.print(rotX);
  Serial.print(" Y=");
  Serial.print(rotY);
  Serial.print(" Z=");
  Serial.print(rotZ);
  Serial.print(" Accel (g)");
  Serial.print(gForceX);
  Serial.print(gForceY);
  Serial.println(gForceZ);
  recordAccelRegisters();
  recordGyroRegisters();
  printData();
  delay(100);
Please edit your post, select all code and click the <CODE> button; next save your post. This will make your code easier to read and easier to copy and the forum software will display it properly.
"comment-out" these two lines to see if you get anything on your Serial Monitor.
Post your wokwi project link.
done, pls help
The project is working now guys, it was a connection issue. It's resolved now. Thank you for your responses.
