I am currently attempting to make a calculator, and this is the first part of the equation where the user will enter a number using an IR remote.
Currently my problem is when I am outputting the numbers I have entered into the array as strings (so I can combine them later on) it outputs odd characters.
My Code so far is:
#include <boarddefs.h>
#include <IRremote.h>
#include <IRremoteInt.h>
#include <ir_Lego_PF_BitStreamEncoder.h>
int RECV_PIN = 6;
IRrecv irrecv(RECV_PIN);
decode_results results;
int part1digits = 0;
String part1[16];
irrecv.enableIRIn(); // Start the receiver
if (part1digits <= 15) {
while (!irrecv.decode(&results)) {
/* DO NOTHING WHEN NO IR SIGNAL IS RECEIVED
This WHILE loop will run continuously, doing nothing
until there IS a signal received
// if IR signals is received, then do this
getCode();
part1digits++;
for (int i = 0; i <= 15; i++) {
Serial.print(part1[part1digits]);
// The while loop below is to 'stop' the program
while(1){}
void getCode() {
if (results.value == 16738455) {
part1[part1digits] = "0";
Serial.println(part1[part1digits]);
else if (results.value == 16724175) {
part1[part1digits] = "1";
else if (results.value == 16718055) {
part1[part1digits] = "2";
else if (results.value == 16743045) {
part1[part1digits] = "3";
else if (results.value == 16716015) {
part1[part1digits] = "4";
else if (results.value == 16726215) {
part1[part1digits] = "5";
else if (results.value == 16734885) {
part1[part1digits] = "6";
else if (results.value == 16728765) {
part1[part1digits] = "7";
else if (results.value == 16730805) {
part1[part1digits] = "8";
else if (results.value == 16732845) {
part1[part1digits] = "9";
// Serial.println(results.value, HEX);
delay(250); // Delay, so you don't send 3 signals back to back
// while the button is depressed.
irrecv.resume(); // Receive the next value
A small snippet of output I am getting after I have entered in all my values are :
ôïÿ9ÝKÏÞóõx;ÿo×§ÿ^Øè«ÙÝ™ë]^ �ßå¿n'Þ
