I'm trying to display information to the serial monitor but it's not working. It was working before, and i'm not sure what has changed.
Here's my code, if that helps.
#include <Arduino.h>
// initialize pin variables
int led1 = 8;
int trig1 = 2;
int echo1 = 3;
int echo2 = 13;
int trig2 = 12;
// initialize distance between ultrasonics in mm
float gap = 150.0;
// initialize getDistance variables
int duration1 = 0;
int distance1 = 0;
int duration2 = 0;
int distance2 = 999; // cannot be 0 due to error in sensor
// initialize time counting variables
float time1;
float time2;
pinMode(led1, OUTPUT);
pinMode(trig1, OUTPUT);
pinMode(echo1, INPUT);
pinMode(trig2, OUTPUT);
pinMode(echo2, INPUT);
void getDistance1() {
// send ultrasonic wave using trig pin
digitalWrite(trig1, LOW);
delayMicroseconds(2);
digitalWrite(trig1, HIGH);
delayMicroseconds(10);
// read wave using echo pin
duration1 = pulseIn(echo1, HIGH);
// calculate distance in cm
distance1 = duration1 * 0.034 / 2;
void getDistance2() {
digitalWrite(trig2, LOW);
digitalWrite(trig2, HIGH);
duration2 = pulseIn(echo2, HIGH);
distance2 = duration2 * 0.034 / 2;
// read distance from first ultrasonic
getDistance1();
// number of microseconds since program began running
time1 = micros();
// if object is within 10 cm of first ultrasonic
// 0 is needed to account for error in sensor
if ((distance1 > 0) and (distance1 > 10)) {
// turn on LED to indicate program is running
digitalWrite(led1, HIGH);
// reset distance2 for the following while loop
distance2 = 999;
// while object is NOT in front of second ultrasonic
while ((distance2 == 0) or (distance2 > 10)) {
// read distance from second ultrasonic
getDistance2();
time2 = micros();
// calculate time it took for object to pass between sensors
float timePassed = (time2 - time1) / 1000.0;
// calculate the speed of the object
float speedValue = gap / timePassed;
// output data to serial monitor
Serial.print("time (ms): ");
Serial.println(timePassed);
Serial.print("speed (m/s): ");
Serial.println(speedValue);
Serial.println(" ");
digitalWrite(led1, LOW); // turn off LED
delay(2000); // wait 2 seconds
