Serial Monitor, non-printable characters
The goal is to use the serial monitor to indicate repeating activity without scrolling or using excessive space in the monitor window.
Tried this:
  char backspace = 8;
  Serial.print( "bb" );
  Serial.print( backspace );  Serial.print( backspace );
  delay( 3000 );
It printed “bb” followed by two small squares.
If there a way to get the serial monitor to backspace and/or delete some already printed characters?
The IDE Serial Monitor doesn't support these characters.
If you want to control the cursor for a formatted output consider using a terminal program that supports ANSI escape sequences and formatting your text output accordingly.
I'm pretty sure PuTTY supports ANSI/VT100 codes.
Is there a way to integrate PuTTY into the Arduino IDE to use during development?
Just run PuTTY and set it for your com port.
No.
