Very new to this but I'm working through the project book that came with my starter kit and I'm currently working on project 5 with the servo motor. Everything seems to be functioning fine once I was done, my issue is with the serial monitor. It doesn't appear to be performing a carriage return after each loop. I've tried selecting all 4 options at the bottom (No line ending, Newline, Carriage return, Both NL & CR) and it still seems to just print continually in one line across.
Not really a huge deal but I just want to be sure its not something I've done or if there is a way to correct it.
This refers only to sending something from serial monitor to the Arduino. Printing a 'new line' on receiving depends wether an new line has been sent by the Arduino. And that's the difference between Serial.print( something ); //without new line
and Serial.println(something); // with new line
That's exactly what it was. Thank you. The last part of my serial.print I had forgotten the "ln" at the end. I even went through past projects knowing i had seen it before but i missed it obviously.
Thanks for the help and sorry for the inconvenience.
