I have the same problem. I am using the esp32 camera server example from the standard examples and the latest arduino 2.0.4. Board ESP32-CAM Board AI-Thinker.The problem is repeated regularly, reboot does not help.
Topic split from another topic. Please do not add your own questions to the end of other people's topics.
Could you take a few moments to Learn How To Use The Forum
Thank you.
Hi @welemirelkrain. When I'm having trouble with serial output, I like to do a quick check with the most simple possible sketch. If this works, then I know the problem has something to do with my real sketch. If it doesn't work, then I know the problem is not related to my sketch code. It seems maybe a little silly, but it allows me to be sure I'm focusing my troubleshooting efforts in the right direction.
Try uploading this sketch to your Arduino board:
Copy and paste this code as a new sketch in Arduino IDE:
void setup() { Serial.begin(9600); } void loop() { Serial.println("hello"); delay(1000); }
- Upload the sketch to your Arduino board.
- Select Tools > Serial Monitor from the Arduino IDE menus to open the Serial Monitor view if it is not already open.
- Make sure the baud rate menu at the top right corner of the Serial Monitor panel is set to "9600".
Do you now see the word "hello" being printed in the Serial Monitor's output field once a second?
