You're right. When I change the delays I get different outputs. I am trying to work on it now.
#include <SoftwareSerial.h>
SoftwareSerial SIM7000E(10, 11); //RX, TX
int rx=10;
int tx=11;
pinMode(tx,OUTPUT);
pinMode(rx,INPUT);
SIM7000E.begin(19200);
Serial.println("Initialising");
char data [16];
SIM7000E.print("AT+CGNSPWR=1\r\n");
if (SIM7000E.available() >= 16){
for (int i=0; i<16; i++) {
data[i] = SIM7000E.read();
Serial.print(data);
Trying to do something like this but nothing is really happening. I just get "Initialising" and then a square box.
I have a feeling the different baud rates are why i am having trouble
By the time your code gets to the if statement, there will more than likely not be 16 characters received. So you will never read the GPS.
while(1)
if (SIM7000E.available())
char c = Serial.read();
if (c < 0x10)
Serial.print("0");
Serial.print(c, HEX);
Serial.print(" ");
You will get an output like
2B 43 47 ...
Those are the HEX representations of the data that you have received. You can look them up on e.g. https://www.asciitable.com/. The last one or two are the important ones for you to continue. They are probably 0A and 0D or a combination of that; 0A is a line feed and 0D is a carriage return.
Once you know that, you can read your SIM data into an array; you need to make sure that your array is big enough to hold the full message plus a terminating '\0'; looking at the output of your opening post, 16 will not be enough !
Those are not perfect but should get you started. Problem with readBytesUntil is that it's blocking for a short while. If that poses a problem, you can read Serial Input Basics - updated to get ideas for non-blocking receive code and you will need a simple mechanism to only send again once you have received the full message.
The main problem is your code is much faster than the speed that data comes in over serial. So the serial buffer empties, and your code keeps going thinking it has received a full reply when it hasn't.
Hey thanks for the suggestion of using readBytesUntil.
However, instead of "SIM7000E.readBytesUntil('\n', data, sizeof(data)),
I used "SIM7000E.readBytesUntil('K', data, sizeof(data))
Because the results for the first ended too early and the coordinates did not show. But the second one works because the results end in "OK". That might not be how it works but at least all the coordinates show.
I was also able to isolate just the coordinates with the following code:
int rx=10;
int tx=11;
pinMode(tx,OUTPUT);
pinMode(rx,INPUT);
char data[128];
SIM7000E.print("AT+CGNSINF\r\n");
SIM7000E.readBytesUntil('K', data, sizeof(data));
char *data1 = strtok(data, ",");
char *data2 = strtok(NULL, ",");
char *data3 = strtok(NULL, ",");
char *data4 = strtok(NULL, ",");
Serial.print(data4);
char *data5 = strtok(NULL, ",");
Serial.print(data5);
That's usually not good enough If the OK had a 0D and/or 0A following it, that will stay on the buffer and might affect the next reading.
The same will happeen if your SIM7000 appends one or both of those characters; reading to e.g. '\n' will leave the OK in the buffer and the next time you will just get that.
Therefore you need to understand what you get back; that could be (I don't know) one line with the GPS information (and some termination) followed by one line with the OK (and some termination).
If you know that you get two lines, read and process one firstand next read (and process if needed) the second line.
Just my thoughts.
Note:
If your topic is solved, please click the solution button under the most useful post to let others know that it is solved.
