Serial Monitor not Printing
I tried to print the BMP180 to the Serial Port yesterday, but I was not sure if it was my program or the serial.print. So I went back to the basics and made a hello.world program to see. It is STILL not printing even though the baud is consistent on both IDE and serial monitor. Code as follows(p.s the led is flashing correctly. I appreciate any help!
static const int heartbeat = 13;
pinMode( heartbeat, OUTPUT );
digitalWrite( heartbeat, HIGH);
Serial.println("Hello");
digitalWrite( heartbeat, LOW);
Code looks 100% kosher. I can't imagine you have disconnected it, so just make sure the monitor is turned on. It's under "Tools" or go CTRL+Shift+M.
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
http://forum.arduino.cc/index.php/topic,148850.0.html.
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What model Arduino and what version IDE are you using?
Try this edit of your code;
You would have been seeing the TX LED flashing as the pin13 LED would not have been ON long enough to see.
static const int heartbeatPin = 13;
  Serial.println("***Hello and LED Test Code***");
  pinMode( heartbeatPin, OUTPUT);
  digitalWrite( heartbeatPin, HIGH);
  digitalWrite( heartbeatPin, LOW);
Tom.. :slight_smile:
Thank you all so much, turns out for some reason my mac serial ports screwed up. It works on my surface, weird stuff!
-sam
Great to see you found the problem, thanks for letting us know the solution.
MACs are weird stuff no matter how they perform! ! ! ! :stuck_out_tongue_closed_eyes: ;D :grinning: ;D
Tom.... :slight_smile:
