Serial Monitor not refreshing
I am trying to read from the DS18B20 sensor and display it on the serial monitor. Initially I thought there was something wrong with the code not retrieving the sensor values but I found out that it was an issue with the serial monitor.
It only displays the the initial temperature, it only shows the temperature change if I close the monitor and open it or refresh it.
What could possibly cause that? How can I resolve it as I need to monitor the temperature data as it changes
It may well be the invisible code you're using on the unknown hardware ! :thinking:
99% certain you are correct. Please post it (using code tags!).
Probably.
... based on ?
