Hi first let me show you the diagram and the code
#include <U8g2lib.h>
#include <DFRobotDFPlayerMini.h>
#include <SoftwareSerial.h>
SoftwareSerial mp3Serial(3, 1); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
U8G2_SH1106_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0);
#define u8g_logo_width 128
#define u8g_logo_height 64
static unsigned char u8g_logo_bits[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFB, 0xFF, 0x3F, 0xE0, 0x07,
0x0E, 0xC0, 0x0F, 0x0E, 0x87, 0x03, 0x7E, 0x00, 0x00, 0x00, 0xFE, 0xFB,
0xFF, 0x3F, 0xF0, 0x0F, 0x0E, 0xE0, 0x1F, 0x0E, 0x87, 0x03, 0xFF, 0x00,
0x00, 0x80, 0xFF, 0xFB, 0xFF, 0x3F, 0xF8, 0x1F, 0x0E, 0xF0, 0x3F, 0x0E,
0x87, 0x83, 0xFF, 0x01, 0x00, 0xC0, 0xFF, 0xFB, 0xFF, 0x3F, 0x7C, 0x1E,
0x0E, 0xF0, 0x3C, 0x9E, 0x87, 0x83, 0xE7, 0x01, 0x00, 0xF0, 0xFF, 0xFB,
0xFF, 0x3F, 0x3C, 0x1C, 0x0E, 0x78, 0x78, 0x9C, 0x83, 0x83, 0xC7, 0x01,
0x00, 0xF8, 0xFF, 0xFB, 0xFF, 0x3F, 0x1C, 0x1C, 0x0E, 0x38, 0x70, 0x9C,
0x83, 0x83, 0x1F, 0x00, 0x00, 0xFC, 0xFF, 0xFB, 0xFF, 0x3F, 0x1C, 0x00,
0x0E, 0x38, 0x70, 0x9C, 0x83, 0x03, 0x7F, 0x00, 0x00, 0xFC, 0xFF, 0xFB,
0xFF, 0x1F, 0x1C, 0x00, 0x0E, 0x38, 0x70, 0x98, 0x81, 0x03, 0xFE, 0x00,
0x00, 0xFE, 0x3F, 0xF8, 0xFF, 0x1F, 0x1C, 0x00, 0x0E, 0x38, 0x70, 0xF8,
0x81, 0x03, 0xF8, 0x01, 0x00, 0xFF, 0x0F, 0xF8, 0xFF, 0x0F, 0x3C, 0x1C,
0x0E, 0x78, 0x78, 0xF8, 0x81, 0x83, 0xE1, 0x01, 0x00, 0xFF, 0x07, 0xF8,
0xFF, 0x0F, 0x7C, 0x1E, 0x0E, 0xF0, 0x3C, 0xF8, 0x81, 0x83, 0xE3, 0x01,
0x80, 0xFF, 0x03, 0xF8, 0xFF, 0x07, 0xF8, 0x1F, 0xFE, 0xF1, 0x3F, 0xF0,
0x80, 0x83, 0xFF, 0x01, 0x80, 0xFF, 0x01, 0xF8, 0xFF, 0x03, 0xF0, 0x0F,
0xFE, 0xE1, 0x1F, 0xF0, 0x80, 0x83, 0xFF, 0x00, 0x80, 0xFF, 0x00, 0xF8,
0xFF, 0x01, 0xE0, 0x07, 0xFE, 0xC1, 0x0F, 0xF0, 0x80, 0x03, 0x7E, 0x00,
0xC0, 0x7F, 0x00, 0xF8, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xC0, 0x7F, 0x00, 0xF8, 0x7F, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x7F, 0x00, 0xF8,
0x3F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xC0, 0x3F, 0x00, 0xF8, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xC0, 0x3F, 0x00, 0xF8, 0x03, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x3F, 0x00, 0x00,
0xC0, 0x3F, 0x00, 0xF8, 0xFF, 0x3F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xC0, 0x3F, 0x00, 0xF8, 0xFF, 0x3F, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x3F, 0x00, 0xF8,
0xFF, 0x3F, 0xF8, 0x0F, 0xFE, 0x03, 0x7C, 0x70, 0x70, 0x00, 0x00, 0x00,
0xC0, 0x7F, 0x00, 0xF8, 0xFF, 0x3F, 0xF8, 0x1F, 0xFE, 0x07, 0x7C, 0xF0,
0x78, 0x00, 0x00, 0x00, 0xC0, 0x7F, 0x00, 0xF8, 0xFF, 0x3F, 0xF8, 0x3F,
0xFE, 0x0F, 0xFE, 0xE0, 0x38, 0x00, 0x00, 0x00, 0xC0, 0x7F, 0x00, 0xF8,
0xFF, 0x3F, 0x38, 0x38, 0x0E, 0x0E, 0xFE, 0xE0, 0x3D, 0x00, 0x00, 0x00,
0x80, 0xFF, 0x00, 0xF8, 0xFF, 0x3F, 0x38, 0x38, 0x0E, 0x0E, 0xFE, 0xC0,
0x1D, 0x00, 0x00, 0x00, 0x80, 0xFF, 0x00, 0xF8, 0xFF, 0x3F, 0xF8, 0x3F,
0x0E, 0x0E, 0xC6, 0xC0, 0x1D, 0x00, 0x00, 0x00, 0x80, 0xFF, 0x01, 0xF8,
0xFF, 0x1F, 0xF8, 0x1F, 0xFE, 0x0F, 0xC7, 0x81, 0x0F, 0x00, 0x00, 0x00,
0x00, 0xFF, 0x03, 0xF8, 0xFF, 0x1F, 0xF8, 0x3F, 0xFE, 0x07, 0xC7, 0x81,
0x0F, 0x00, 0x00, 0x00, 0x00, 0xFF, 0x0F, 0xF8, 0xFF, 0x0F, 0xF8, 0x3F,
0xFE, 0x03, 0xFF, 0x01, 0x07, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x3F, 0xF8,
0xFF, 0x0F, 0x38, 0x38, 0x8E, 0x07, 0xFF, 0x01, 0x07, 0x00, 0x00, 0x00,
0x00, 0xFE, 0xFF, 0xFB, 0xFF, 0x07, 0x38, 0x38, 0x0E, 0x87, 0xFF, 0x03,
0x07, 0x00, 0x00, 0x00, 0x00, 0xFC, 0xFF, 0xFB, 0xFF, 0x03, 0xF8, 0x3F,
0x0E, 0x87, 0x83, 0x03, 0x07, 0x00, 0x00, 0x00, 0x00, 0xF8, 0xFF, 0xFB,
0xFF, 0x01, 0xF8, 0x1F, 0x0E, 0x8F, 0x83, 0x03, 0x07, 0x00, 0x00, 0x00,
0x00, 0xF0, 0xFF, 0xFB, 0xFF, 0x00, 0xF8, 0x0F, 0x0E, 0x8F, 0x83, 0x03,
0x07, 0x00, 0x00, 0x00, 0x00, 0xE0, 0xFF, 0xFB, 0x7F, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xFF, 0xFB,
0x00, 0x00, 0xFF, 0xFB, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0xFB, 0x01, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x45, 0x1C, 0x89,
0xBC, 0xE7, 0x91, 0xC8, 0x81, 0x43, 0x0C, 0xC3, 0x89, 0x9E, 0x27, 0x02,
0x20, 0x4C, 0x22, 0x99, 0x84, 0x20, 0x92, 0x29, 0x82, 0x44, 0x92, 0x24,
0x8A, 0x82, 0x48, 0x01, 0xE0, 0x54, 0x02, 0xA9, 0x9C, 0x23, 0x92, 0x2A,
0x80, 0x48, 0x86, 0x20, 0x52, 0x8E, 0x88, 0x00, 0x20, 0x54, 0x32, 0xA9,
0x84, 0xE0, 0x91, 0x2A, 0x83, 0x48, 0x98, 0x20, 0x52, 0x82, 0x87, 0x00,
0x20, 0x64, 0x22, 0xC9, 0x84, 0x20, 0x91, 0x2C, 0x82, 0x44, 0x92, 0x24,
0x52, 0x82, 0x84, 0x00, 0xE0, 0x45, 0x3C, 0x89, 0xBC, 0x27, 0x92, 0xC8,
0x83, 0x43, 0x0C, 0xC3, 0x21, 0x9E, 0x88, 0x00, 0x00, 0x00, 0x00, 0x00,
int Green1 = D3;
int Red1 = D4;
int Blue1 = D5;
int Green2 = D6;
int Red2 = D7;
int Blue2 = D8;
void setup(void) {
pinMode ( Green1, OUTPUT);
pinMode ( Red1, OUTPUT);
pinMode ( Blue1, OUTPUT);
pinMode ( Green2, OUTPUT);
pinMode ( Red2, OUTPUT);
pinMode ( Blue2, OUTPUT);
u8g2.begin();
u8g2.setFlipMode(1);
Serial.begin (115200);
mp3Serial.begin (9600);
myDFPlayer.begin (mp3Serial);
myDFPlayer.volume(10);
myDFPlayer.EQ(DFPLAYER_EQ_BASS);
u8g2.firstPage();
do {
u8g2.drawXBM( 0, 0, u8g_logo_width, u8g_logo_height, u8g_logo_bits);
} while ( u8g2.nextPage() );
/// delay(3000);
myDFPlayer.play(1);
void loop(void) {
Serial.println(100);
Note: please read everything before jumping to conclusions XD and there will be some important notes at the end :
As you can see the code is not finished yet but that's not the issue the issue is I can't see anything on the Serial Monitor.
I started troubleshooting and made sure that the settings for SM and the IDE are correct.
I ended up figuring out that if I used SoftwareSerial the problem happens.
for example, this simple test code works fine on the same NodMCU
But if I used the SoftwareSerial in this simple code nothing shows up on the serial monitor !
Can you help?
