Serial Monitor not showing right
My serial monitor is acting weird. First of all i´ve selected new line but everything goes in one infinte line. When i say print it doenst print out anything i´ve tried it with flush before cuz i came across this method on the internet but with no luck.
Serial.begin(9600); // Starts the serial communication
Serial.print("Distance: ");
i´ve tried this with the Ultrasonic sensor but i only get weird outputs like
0.33.0,0.34.0,0.35.0, and so on
baud rate is the same i´ve tried printing out other hardcoded variables but also with no luck
Hope someone can help me here thanks in advanced
(deleted)
I told you in the issue report what you needed to do to get help here:
Please do this:
but you completely ignored my advice. It's almost as if you don't really want a solution to your problem.
Newline only applies to the sending from the serial monitor. To see newlines in the 'receive window', the arduino board has to send them.
Without seeing complete code, a guess is that you haven't figured out the difference between print and println.
