Serial monitor or Serial plotter?
Hello! I'm looking forward to doing a simulation of a signal related to my heartbeat sensor. And I don't know if the following program is going to show me the result using the serial monitor or the serial plotter ??
When I use the serial monitor, I'm expecting a signal that is representing my heart rate. And when I use the serial monitor, I'm expecting to see this message ":heart: A HeartBeat Happened" followed by my heartbeat per minute.
I don't know which one is already provided by the program ?
( I'm a newbie, please be patient! )
What else can I provide in order to get some help ?
#define USE_ARDUINO_INTERRUPTS false
#include <PulseSensorPlayground.h>
   The format of our output.
   Set this to PROCESSING_VISUALIZER if you're going to run
    the Processing Visualizer Sketch.
    See https://github.com/WorldFamousElectronics/PulseSensor_Amped_Processing_Visualizer
   Set this to SERIAL_PLOTTER if you're going to run
    the Arduino IDE's Serial Plotter.
const int OUTPUT_TYPE = SERIAL_PLOTTER;
const int PULSE_INPUT = A0;  //PIN A0 is on Signal of Pulse sensor
const int PULSE_BLINK = 13;    // Pin 13 is the on-board LED
const int THRESHOLD = 600;   // A ajuster en fonction de votre montage
   samplesUntilReport = the number of samples remaining to read
   until we want to report a sample over the serial connection.
   We want to report a sample value over the serial port
   only once every 20 milliseconds (10 samples) to avoid
   doing Serial output faster than the Arduino can send.
byte samplesUntilReport;
const byte SAMPLES_PER_SERIAL_SAMPLE = 10;
   All the PulseSensor Playground functions.
PulseSensorPlayground pulseSensor;
/*LEDS
int ledPins[] = {
  2, 3, 4, 5, 6, 7, 8, 9, 10, 11
};       // an array of pin numbers to which LEDs are attached
int pinCount = 10;
//Minimum heart rate value to display on the LEDs
const byte bpmMin = 40;
const byte bpmMax = 110;
//SETUP
  // Configure the PulseSensor manager.
  pulseSensor.analogInput(PULSE_INPUT);
  pulseSensor.blinkOnPulse(PULSE_BLINK);
  pulseSensor.setSerial(Serial);
  pulseSensor.setOutputType(OUTPUT_TYPE);
  pulseSensor.setThreshold(THRESHOLD);
  //LEDS SETUP in Output
  for (int thisPin = 0; thisPin < pinCount; thisPin++) {
    pinMode(ledPins[thisPin], OUTPUT);
  // Now that everything is ready, start reading the PulseSensor signal.
  if (!pulseSensor.begin()) {//FAILED
       PulseSensor initialization failed,
       likely because our Arduino platform interrupts
       aren't supported yet.
       If your Sketch hangs here, try changing USE_PS_INTERRUPT to false.
    for (;;) {
      // Flash the led to show things didn't work.
      digitalWrite(PULSE_BLINK, LOW);
      delay(100);
      digitalWrite(PULSE_BLINK, HIGH);
      delay(100);
     See if a sample is ready from the PulseSensor.
     If USE_INTERRUPTS is true, the PulseSensor Playground
     will automatically read and process samples from
     the PulseSensor.
     If USE_INTERRUPTS is false, this call to sawNewSample()
     will, if enough time has passed, read and process a
     sample (analog voltage) from the PulseSensor.
  if (pulseSensor.sawNewSample()) {
       Every so often, send the latest Sample.
       We don't print every sample, because our baud rate
       won't support that much I/O.
    if (--samplesUntilReport == (byte) 0) {
      samplesUntilReport = SAMPLES_PER_SERIAL_SAMPLE;
      pulseSensor.outputSample();
         At about the beginning of every heartbeat,
         report the heart rate and inter-beat-interval.
      if (pulseSensor.sawStartOfBeat()) {
        pulseSensor.outputBeat();
        int myBPM = pulseSensor.getBeatsPerMinute();
        Serial.println("♥  A HeartBeat Happened ! "); // If test is "true", print a message "a heartbeat happened".
        Serial.print("BPM: ");                        // Print phrase "BPM: "
        Serial.println(myBPM);
        if ( myBPM >= bpmMin && myBPM <= bpmMax ) {
          int purcent  = map(myBPM, bpmMin , bpmMax, 0, 100);
          lightLed100(purcent);
          delay(100);
          lightLed100(0);
          lightLed100(0);
     Don't add code here, because it could slow the sampling
//Led on in purcentage
void lightLed100(int pourcent) {
  //put to LOW first
    digitalWrite(ledPins[thisPin], LOW);
  //PINS TO HIGH
  int pinsToHigh  = map(pourcent, 0 , 100, 0, pinCount);
  for (int thisPin = 0; thisPin < pinsToHigh; thisPin++) {
    digitalWrite(ledPins[thisPin], HIGH);
On Serial Monitor, you can display any characters you like. On Serial Plotter, it is expecting lines of comma-separated numbers.
To use Serial Plotter, just comment out the first two prints:
        // Serial.println("♥  A HeartBeat Happened ! "); // If test is "true", print a message "a heartbeat happened".
        // Serial.print("BPM: ");                        // Print phrase "BPM: "
Then you will get a graph of BPM for the last 500 heartbeats. You can switch to Serial Monitor to get the list of BPM values. You already know that each one represents BPM and each one is sent when a beat is detected.
@johnwasser Thanks for your help!! I noticed that in the beginning of the program, it is mentioned that the type of the output is serial plotter, so do I need to add the serial monitor ?
I wish I'm asking the right question, I'm not very familiar with Arduino and coding.
It looks like the PulseSensorPlayground library has some provision for serial output but it is not clear if that feature is being used for serial output. If that feature is not being used, I don't think it matters what you pass to pulseSensor.setOutputType().
Thanks for your help!! @johnwasser I wanna ask you please, I don't really understand this comment related to samplesUntilReport. Could you clarify it for me, please ?
Look at how the value is used:
