Hello,
I have made a code in measuring time, date, longitude and latitude from a sensor. Serial monitor output is correct however, the output written through the SD card is incorrect.
Here's my code:
Get the high precision geodetic solution for latitude and longitude
By: Nathan Seidle, Steven Rowland and Paul Clark
SparkFun Electronics
Modified by: Katrina Cereno
Klohn Crippen Berger Ltd.
Date: August 24, 2022
License: MIT. See license file for more information but you can
basically do whatever you want with this code.
This example shows how to inspect the accuracy of the high-precision
positional solution. Please see below for information about the units.
#include <SD.h>
#include <Wire.h> //Needed for I2C to GNSS
#include <SparkFun_u-blox_GNSS_Arduino_Library.h> //http://librarymanager/All#SparkFun_u-blox_GNSS
SFE_UBLOX_GNSS myGNSS;
#define PIN_SPI_CS 4
long lastTime = 0; //Simple local timer. Limits amount if I2C traffic to u-blox module.
File myFile;
Serial.begin(57600);
while (!Serial)
; //Wait for user to open terminal
if (!SD.begin(PIN_SPI_CS)) {
Serial.println(F("SD CARD FAILED, OR NOT PRESENT!"));
while (1); // don't do anything more:
Serial.println(F("SD CARD INITIALIZED."));
Wire.begin();
if (myGNSS.begin(Wire) == false) //Connect to the u-blox module using Wire port
Serial.println(F("Please check wiring. Freezing."));
while (1);
myGNSS.setI2COutput(COM_TYPE_UBX); //Set the I2C port to output UBX only (turn off NMEA noise)
myGNSS.setNavigationFrequency(20); //Set output to 20 times a second
//Query module only every second. Doing it more often will just cause I2C traffic.
if (millis() - lastTime > 60000)
lastTime = millis(); //Update the timer
// Print date and time
Serial.print(myGNSS.getYear());
Serial.print(F("-"));
Serial.print(myGNSS.getMonth());
Serial.print(myGNSS.getDay());
Serial.print(F(","));
Serial.print(myGNSS.getHour());
Serial.print(F(":"));
Serial.print(myGNSS.getMinute());
Serial.print(myGNSS.getSecond());
// Collect the position data
int32_t latitude = myGNSS.getHighResLatitude();
int8_t latitudeHp = myGNSS.getHighResLatitudeHp();
int32_t longitude = myGNSS.getHighResLongitude();
int8_t longitudeHp = myGNSS.getHighResLongitudeHp();
/* int32_t ellipsoid = myGNSS.getElipsoid();
int8_t ellipsoidHp = myGNSS.getElipsoidHp();
int32_t msl = myGNSS.getMeanSeaLevel();
int8_t mslHp = myGNSS.getMeanSeaLevelHp();*/
uint32_t accuracy = myGNSS.getHorizontalAccuracy();
// Defines storage for the lat and lon units integer and fractional parts
int32_t lat_int; // Integer part of the latitude in degrees
int32_t lat_frac; // Fractional part of the latitude
int32_t lon_int; // Integer part of the longitude in degrees
int32_t lon_frac; // Fractional part of the longitude
// Calculate the latitude and longitude integer and fractional parts
lat_int = latitude / 10000000; // Convert latitude from degrees * 10^-7 to Degrees
lat_frac = latitude - (lat_int * 10000000); // Calculate the fractional part of the latitude
lat_frac = (lat_frac * 100) + latitudeHp; // Now add the high resolution component
if (lat_frac < 0) // If the fractional part is negative, remove the minus sign
lat_frac = 0 - lat_frac;
lon_int = longitude / 10000000; // Convert latitude from degrees * 10^-7 to Degrees
lon_frac = longitude - (lon_int * 10000000); // Calculate the fractional part of the longitude
lon_frac = (lon_frac * 100) + longitudeHp; // Now add the high resolution component
if (lon_frac < 0) // If the fractional part is negative, remove the minus sign
lon_frac = 0 - lon_frac;
// Print the lat and lon
Serial.print(lat_int); // Print the integer part of the latitude
Serial.print(".");
printFractional(lat_frac, 9); // Print the fractional part of the latitude with leading zeros
Serial.print(",");
Serial.print(lon_int); // Print the integer part of the latitude
Serial.print(".");
printFractional(lon_frac, 9); // Print the fractional part of the latitude with leading zeros
File dataFile = SD.open("neom8p.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.print(myGNSS.getYear());
dataFile.print(F("-"));
dataFile.print(myGNSS.getMonth());
dataFile.print(myGNSS.getDay());
dataFile.print(F(","));
dataFile.print(myGNSS.getHour());
dataFile.print(F(":"));
dataFile.print(myGNSS.getMinute());
dataFile.print(myGNSS.getSecond());
dataFile.print(lat_int); // Print the integer part of the latitude
dataFile.print(".");
dataFile.print(lat_frac, 9); // Print the fractional part of the latitude with leading zeros
dataFile.print(",");
dataFile.print(lon_int); // Print the integer part of the latitude
dataFile.print(lon_frac, 9); // Print the fractional part of the latitude with leading zeros
dataFile.println("");
dataFile.close();
// prints to the serial port too:
// Pretty-print the fractional part with leading zeros - without using printf
// (Only works with positive numbers)
void printFractional(int32_t fractional, uint8_t places)
if (places > 1)
for (uint8_t place = places - 1; place > 0; place--)
if (fractional < pow(10, place))
Serial.print("0");
Serial.print(fractional);
Would someone be able to help me fix my code?
Thank you!
