Serial monitor output
Hey this might be a simple and stupid question, but i simply can't figure it out.
How do you get more columns in the serial monitor?
I have two sensor numbers right now and are using Serial.println() to get the numbers.
The numbers are coming one at a time, crazy fast, so i can't see which is which.
It could be nice to make it say:
thisSensor = this number | nextSensor = next number
Please help...
use print() instad of println() and a suitable number of spaces
Thanks for the answer Udo Klein, but it didn't work the way i thought it.
using print(), the numbers just keeps going to the right, instead of down.
Any other ideas?
For the FIRST number. Keep using println() for the second.
Add a delay() in loop() to slow stuff down.
Ok fantastic it works.
But what can i use for spaces?
Right now they are too close to each other.
Cut and paste some of these: " "
Sounds right, but i can't figure out where to place it.
Nevermind i figured it out by using char myString[] and then .print()
Thanks for the help
You can also use the tab character.
Serial.print('\t');
