I have a file, TEST2.TXT
, on an SD card that has the following content:
100
200
But when I print out each character to the serial monitor there's a mysterious invisible character at index 3. Index 4 looks to be the '\n' character.
Serial Monitor:
01:04:00.436 -> index 0: 1
01:04:00.436 -> index 1: 0
01:04:00.436 -> index 2: 0
01:04:00.436 -> index 3:
01:04:00.436 -> index 4:
01:04:00.436 ->
01:04:00.436 -> index 5: 2
01:04:00.436 -> index 6: 0
01:04:00.436 -> index 7: 0
What is index 3? Also is there a way to serial print in a way that I can actually see what index 3 is?
Note: The above serial monitor section shows what I see in the serial monitor. But when I copy and paste the serial monitor text, this text editor is interpreting a carriage return at index 3. But why would there be two carriage returns printed differently?
01:04:00.436 ->
Full Code:
#include <SPI.h>
#include <SD.h>
File myFile;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
if (!SD.begin(5)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
myFile = SD.open("test2.txt");
if (!myFile) {
// if the file didn't open, print an error:
Serial.println("error opening file");
if (myFile) {
byte numOfChar = 0 ;
while ( myFile.available()) {
char newChar = myFile.read();
Serial.print("index ");
Serial.print(numOfChar);
Serial.print(": ");
Serial.println(newChar);
numOfChar++;
