* Example code for using a microchip mrf24j40 module to send and receive
* packets using plain 802.15.4
* Requirements: 3 pins for spi, 3 pins for reset, chip select and interrupt
* notifications
* This example file is considered to be in the public domain
* Originally written by Karl Palsson, karlp@tweak.net.au, March 2011
#include <SPI.h>
#include <mrf24j.h>
#include <dht.h>
dht DHT;
#define DHT22_PIN 7
const int pin_reset = 6;
const int pin_cs = 52; // default CS pin on ATmega8/168/328
const int pin_interrupt = 5; // default interrupt pin on ATmega8/168/328
Mrf24j mrf(pin_reset, pin_cs, pin_interrupt);
long last_time;
long tx_interval = 1000;
 SPI.setBitOrder(MSBFIRST) ;
  SPI.setDataMode(SPI_MODE0);
  SPI.begin();
 mrf.reset();
 mrf.init();
 mrf.set_pan(0x1234);
 // This is _our_ address
 mrf.address16_write(0x6002);
 // uncomment if you want to receive any packet on this channel
 mrf.set_promiscuous(true);
 //uncomment if you want to enable PA/LNA external control
 //mrf.set_palna(true);
 // uncomment if you want to buffer all PHY Payload
 mrf.set_bufferPHY(true);
 attachInterrupt(pin_interrupt, interrupt_routine, CHANGE); // interrupt 0 equivalent to pin 2(INT0) on ATmega8/168/328
 last_time = millis();
 interrupts();
void interrupt_routine() {
  mrf.interrupt_handler(); // mrf24 object interrupt routine
int H;
String str;
char HH[3];
  mrf.check_flags(&handle_rx, &handle_tx);
  unsigned long current_time = millis();
  if (current_time - last_time > tx_interval) {
    last_time = current_time;
  Â
    uint32_t start = micros();
  int chk = DHT.read22(DHT22_PIN);
  uint32_t stop = micros();
Â
Â
//Â Â // DISPLAY DATA
  Serial.print(DHT.humidity, 1);
  Serial.print(",\t");
  Serial.print(DHT.temperature, 1);
  Serial.print(stop - start);
Â
  H=int(DHT.humidity);
  str=String(H);
  str.toCharArray(HH,3);
Â
  Serial.print(HH);
Â
    Serial.println("txxxing...");
    mrf.send16(0x6001, HH);
  Â
void handle_rx() {
  Serial.print("received a packet ");Serial.print(mrf.get_rxinfo()->frame_length, DEC);Serial.println(" bytes long");
Â
  if(mrf.get_bufferPHY()){
   Serial.println("Packet data (PHY Payload):");
   for (int i = 0; i < mrf.get_rxinfo()->frame_length; i++) {
     Serial.print(mrf.get_rxbuf()[i]);
Â
  Serial.println("\r\nASCII data (relevant data):");
  for (int i = 0; i < mrf.rx_datalength(); i++) {
    Serial.write(mrf.get_rxinfo()->rx_data[i]);
Â
  Serial.print("\r\nLQI/RSSI=");
  Serial.print(mrf.get_rxinfo()->lqi, DEC);
  Serial.print("/");
  Serial.println(mrf.get_rxinfo()->rssi, DEC);
void handle_tx() {
  if (mrf.get_txinfo()->tx_ok) {
    Serial.println("TX went ok, got ack \n");
    Serial.print("TX failed after \n ");Serial.print(mrf.get_txinfo()->retries);Serial.println(" retries\n");
When the Serial Monitor is opened it causes the Arduino to reset. It would be worth checking to see if pressing the reset button gets things moving when the Serial Monitor is not used.
There is a great deal of Serial stuff in your code. What happens if you comment it out ?
Though I doubt if that is the problem.
The device seems to be very similar to the NRF24 transceivers.
What is the purpose of the handle_rx() and handle_tx() functions ?
If they are called by tge mrf library when data arrives (or is sent) I would certainly not put ANY print statements in them.
I notice, for example that you have
which would be much easier to read like this
but the main point is that it has that mrf.get in it and I have no idea how that might behave without a serial connection. It could be filling the serial tx buffer and getting stuck.
I would just use the handle_rx() function to place the received data in my own buffer from which I could print it from loop().
Also I rarely use the result of a function in another function. If I save the result to a variable it gives me the opportunity to print the value for debugging purposes (but not within handle_rx() )
interrupt_handler disables interrupts, so just to test comment the noInterrupts out, and or find a way to invoke Serial prints after the interrupt_handler is finished.
Actually - using Serial in ISR leads to unreliable code, but it still does not explain why it works with the "remote" COM enabled.
I am not 100% sure this will solve the problem.
PS I now know how the TX / RX is invoked, so skip my request.
