Serial Monitor Problem
Hi everyone.
I can’t open Serial Monitor.
I reinstall Java and Arduino IDE but it didn’t work.
Please help.
~Windows 10 64-bit
~Arduino Uno
The error message is:
Exception in thread "AWT-EventQueue-0" java.lang.UnsatisfiedLinkError: C:\Users\MÜCAHİT\.jssc\windows\jSSC-2.8_x86.dll: Can't find dependent libraries
	at java.lang.ClassLoader$NativeLibrary.load(Native Method)
	at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1941)
	at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1824)
	at java.lang.Runtime.load0(Runtime.java:809)
	at java.lang.System.load(System.java:1086)
	at jssc.SerialNativeInterface.<clinit>(SerialNativeInterface.java:172)
	at jssc.SerialPort.<init>(SerialPort.java:120)
	at processing.app.Serial.<init>(Serial.java:135)
	at processing.app.Serial.<init>(Serial.java:82)
	at processing.app.SerialMonitor$4.<init>(SerialMonitor.java:101)
	at processing.app.SerialMonitor.open(SerialMonitor.java:101)
	at processing.app.Editor.handleSerial(Editor.java:2251)
	at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:383)
	at java.awt.Component.processMouseEvent(Component.java:6530)
	at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
	at java.awt.Component.processEvent(Component.java:6298)
	at java.awt.Container.processEvent(Container.java:2238)
	at java.awt.Component.dispatchEventImpl(Component.java:4889)
	at java.awt.Container.dispatchEventImpl(Container.java:2296)
	at java.awt.Component.dispatchEvent(Component.java:4711)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4897)
	at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4531)
	at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4475)
	at java.awt.Container.dispatchEventImpl(Container.java:2282)
	at java.awt.Window.dispatchEventImpl(Window.java:2746)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
	at java.awt.EventQueue.access$500(EventQueue.java:97)
	at java.awt.EventQueue$3.run(EventQueue.java:709)
	at java.awt.EventQueue$3.run(EventQueue.java:703)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
	at java.awt.EventQueue$4.run(EventQueue.java:733)
	at java.awt.EventQueue$4.run(EventQueue.java:731)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
	at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Please provide the following information to help describe situation:
What type of hardware? (Uno, Mega, etc.)
What type PC and OS Version?
Are you using the latest version (1.8.7) of the official Arduino IDE downloaded from:
Please don't reply by editing your original post because then we don't get a notification of the reply. Likely DaleScott never knew that you had answered their questions.
It's not working because now Arduino IDE became Unicodophobe :smiley:
You need to create another user account on Windows that contain only English character as "Test"
Then you need to run Arduino with that user account and it's working.
This problem to not supporting Unicode username affect some other software, so just run the software as the username that contain only English character to solve the problem.
