Serial Monitor Problem
Hello there.
I am receiving two analog readings from arduino nano to arduino uno using RF modules.Until now everything is fine.I am applying some code on this analoge reading.when i try to display these lines on serial monitor
Serial.print(speedLeft);
    Serial.print("\t" );
    Serial.print(speedRight);
    Serial.println(" ");
serial monitor suddenly stop displaying at a certain result.
Later i noticed that the problem is from this code line:
analogWrite(pwm1, abs(spdR));
When i disable this line everything goes right.
This is the full Code:
#include <RH_ASK.h>
#include <SPI.h> // Not actualy used but needed to compile
const byte pwm2 = 10;//motorLSpeedPin
const byte dir2 = 8;//motorLDirPin
const byte pwm1 = 9;//motorRSpeedPin
const byte dir1 = 7;//motorRDirPin
//variables
//Joystick input variables
int joyXValue = 0;//horizontal
int joyYValue = 0;//vertical
int joyValueMax = 1023;
int joyValueMin = 0;
int joyValueMid = 511;
int joyValueMidUpper = joyValueMid + 10;
int joyValueMidLower = joyValueMid - 10;
//DC motor variables
int speedFwd = 0;
int speedTurn = 0;
int speedLeft = 0;
int speedRight = 0;
byte motorSpeed = 0;
byte motorSpeedMax = 255;
byte motorSpeedMin = 0; //set to smallest value that make motor move (default 0)
                         // DC motor that I use start to move at 90 pwm value
RH_ASK driver;
void setup(){
    pinMode(pwm2, OUTPUT);
    pinMode(dir2, OUTPUT);
    pinMode(pwm1, OUTPUT);
    pinMode(dir1, OUTPUT);
    Serial.begin(9600);  // Debugging only
    if (!driver.init())
         Serial.println("init failed");
void loop(){
    uint8_t buf[4];
    uint8_t buflen = sizeof(buf);
    if (driver.recv(buf, &buflen)) // Non-blocking
       joyXValue=(buf[1]<<8)|buf[0];
       joyYValue=(buf[3]<<8)|buf[2];
      // Serial.print(joyXValue);// Horizontal.
      // Serial.print("H<==============>V");
      // Serial.println(joyYValue);//vertical..
   if(joyYValue > 521)//backward
        speedFwd = map(joyYValue, 521, 1023, 0, 255);//map(joyYValue,joyValueMidUpper,joyValueMax,motorSpeedMin,motorSpeedMax
    else if(joyYValue < 501) //forward
        speedFwd = map(joyYValue, 501, 0, 0, -255);//map(joyYValue,joyValueMidLower,joyValueMin,-motorSpeedMin,-motorSpeedMax
       speedFwd =0;
    if(joyXValue > 521) //right
        speedTurn = map(joyXValue, 521, 1023, 0, 255);
    else if(joyXValue < 501) //left
        speedTurn = map(joyXValue, 501, 0, 0, -255);
       speedTurn =0;
    speedLeft = speedFwd + speedTurn;
    speedRight = speedFwd - speedTurn;
    speedLeft = constrain(speedLeft, -255, 255);
    speedRight = constrain(speedRight, -255, 255);
   MoveRobot(speedLeft,speedRight);
  //  Serial.print(speedFwd);
   // Serial.print("\t" );
   // Serial.print(speedTurn);
    Serial.println(" ");*/
} //End void loop
void MoveRobot(int spdL, int spdR){
     if(spdL>0)
        digitalWrite(dir2, HIGH);
        digitalWrite(dir2, LOW);
     if(spdR>0)
        digitalWrite(dir1, HIGH);
        digitalWrite(dir1, LOW);
      analogWrite(pwm2, abs(spdL));
     // analogWrite(pwm1, abs(spdR));// the problem in this code.
The RadioHead code uses timer 1 to generate interrupts. It needs the OCR1A register to set the time period for these interrupts. As the PWM on pin 9 uses the same register to set the pulse width it cannot work. You should also not use PWM on pin 10 as it needs the same timer and may interfere the correct working of the RadioHead code.
Alternatively you can edit the RH_ASK.h file and activate to use timer 2 for it. The PWM pins of timer 2 are 3 and 11 so your project shouldn't have a problem with that.
Thanks alot Pylon.
I changed pwm to be pin 5 and 6, and every thing goes right. :slight_smile:
