Serial Monitor reads LED PWM value and Photodiode Value
I'm trying to write a program that has an LED fading in/out using PWM and then have a photodiode reading out the value. I am using an Arduino Uno. So far, my photodiode code is all working correctly. I am getting the values I expect and they change depending on the LED. My issue, though, is getting a value of the LED brightness. Is there a way to have the serial monitor show the brightness of the LED in one column and the photodiode reading in another? This is my code so far:
//Initializing LED Pin
int led_pin = 6;
int sensorPin = A0;
int sensorValue = 0;
int ledValue = 0;
//Declaring LED pin as output
pinMode(sensorPin, INPUT); //sensor input
pinMode(led_pin, OUTPUT);
//Fading the LED
for(int i=0; i<255; i++){
analogWrite(led_pin, i);
delay(5);
sensorValue = analogRead(sensorPin);
ledValue = digitalRead(led_pin);
Serial.println(sensorValue);
Serial.println(ledValue);
for(int i=255; i>0; i--){
delay(5);
Right now, the monitor looks like this:
The 0 is for when the LED is fading off and the 1 is for when it is fading on.
Instead of
use
Serial.print(sensorValue);
Serial.print("   ");
Thank you so much! is there a way I can get the LED to read off the value of the PWM on a scale insead of just 0 vs. 1. Sorry if my wording is weird I am very new to arduino.
Serial.print("\t");
Serial.print(ledValue);
Serial.print("\t");
Serial.println(i);
i like my columns to be lined up regardless of the number of digits
    char s [80];
    sprintf (s, " %d %6d", ledValue, sensorValue)
    Serial.println (s);
I think the data will be easier to understand if you display it on Serial Plotter. I would divide the sensorValue by 4 to get both signals in the 0-255 range.
const int led_pin = 6;  // Must be PWM pin
const int sensorPin = A0;
  //Fading the LED
  for (int i = 0; i < 255; i++)
    delay(5);
    int sensorValue = analogRead(sensorPin);
    Serial.print(sensorValue / 4);
    Serial.print(',');
    Serial.println(i);
  for (int i = 255; i > 0; i--)
    delay(5);
    Serial.print(',');
    Serial.println(i);
Tools > Serial Plotter
Hadn't noticed.
How long has that been around?
Only about 7 years. :slight_smile:
Release notes:
ARDUINO 1.6.6 - 2015.11.03
* Added Serial Plotter. Thanks @henningpohl
A post was split to a new topic: Interact the LED with photo diode
