Hello everyone,
I have been working on a project that uses two IMUs, specifically the MIKROE-1996 board with the LSM9DS1, these two sensors are above a steel pipe and a motor moves them along said pipe. The sensors communicate with the Arduino by I2C.
I am interested in obtaining the magnetometers readings and send the 6 values (3 for each axis of each sensor) through the serial port to my laptop, catch those values in Matlab and store them in a matrix.
I have written the sketch to drive the motor with an H-bridge and read from the sensors and send the measurements, and also the code in Matlab to read the serial port and store the information as described. These two codes work correctly to some extent and I haven't been able to find a solution to my problem after reading a lot of posts in this and other similar forums. Let me describe my problem:
As previously said, I read 6 values from the 2 sensors and send them to the serial monitor. If I open the monitor, I can see the 6 values separated by a comma. There is a 50ms delay between each print. To drive the motor, I send a command through the serial port. After a few moments with the motor ON, the serial monitor stops showing the measurements. However, if I don't send any command to turn the motor on (forward or backward), the serial monitor never stops sending the values. I tested this by leaving the code running for almost two hours and it didn't stop, but when I turn the motor on sometimes the code stops after 30 seconds or 50 seconds, it's not even consistent on that. Also, when the monitor stops printing I can't send other commands to stop the motor's movement.
Originally, I thought it was a problem with my code in Matlab and started tweaking some parts of my code, but after some tests using only the Arduino IDE I realized it was a problem with my sketch, one that I haven't been able to find. The serial monitor starts printing again only when I manually reset the Arduino board. Something strange about this is that the serial monitor only stops when the motor is moving in a direction but not in the opposite.
This is my code, I omitted all the setting up of the sensors:
// Magnetoresistive sensors and motor driver
#include <Wire.h>
#include <SPI.h>
#include <SparkFunLSM9DS1.h>
int motorcito[] = {12, 13}; //Output pins to control H-bridge
LSM9DS1 sensor1; //Creating LSM9DS1 objects
LSM9DS1 sensor2; //
#define PRINT_SPEED 50 // 50 ms between prints
static unsigned long lastPrint = 0; // Keep track of print time
pinMode(motorcito[0], OUTPUT);
pinMode(motorcito[1], OUTPUT);
///////////// Setting up sensors ////////////
if (Serial.available() > 0) {
char data = Serial.read();
//Serial.print("data: ");
switch (data) {
case 'f':
motor_forward();
case 'b':
motor_backward();
case 's':
motor_stop();
default:
// Update sensor values when new data available
if ( sensor1.magAvailable() || sensor2.magAvailable())
sensor1.readMag();
sensor2.readMag();
if ((lastPrint + PRINT_SPEED) < millis()) {
printMag(); // Print magnetometer readings
lastPrint = millis();
Serial.flush(); //I included this function because I read that it might be useful
//but I'm not completely sure about it
void motor_stop() {
digitalWrite(motorcito[0], LOW);
digitalWrite(motorcito[1], LOW);
void motor_forward() {
digitalWrite(motorcito[0], HIGH);
void motor_backward() {
digitalWrite(motorcito[1], HIGH);
void printMag() {
Serial.print(sensor1.calcMag(sensor1.mx), 4);
Serial.print(F(","));
Serial.print(sensor1.calcMag(sensor1.my), 4);
Serial.print(sensor1.calcMag(sensor1.mz), 4);
Serial.print(sensor2.calcMag(sensor2.mx), 4);
Serial.print(sensor2.calcMag(sensor2.my), 4);
Serial.print(sensor2.calcMag(sensor2.mz), 4);
Serial.println(F(","));
// I am using the F() macro because I found it might be useful but I didn't see any improvement with it
