Serial Monitor Stops Receiving Data
Board: Nano V3.0
I am using an MPU6050 to get roll and pitch. However, the serial monitor data stops at random time and I receive data again only after pressing the reset pin. Also the roll and pitch data I get is not correct, it should be between +-180' but at times I get 200' +
Code:
/* Get all possible data from MPU6050
 * Accelerometer values are given as multiple of the gravity [1g = 9.81 m/s²]
 * Gyro values are given in deg/s
 * Angles are given in degrees
 * Note that X and Y are tilt angles and not pitch/roll.
#include "Wire.h"
#include <MPU6050_light.h>
MPU6050 mpu(Wire);
unsigned long lastTime, lastInterval;
float accelX, accelY, accelZ,  // units m/s/s i.e. accelZ if often 9.8 (gravity)
  gyroX, gyroY, gyroZ,         // units dps (degrees per second)
  gyroDriftX, gyroDriftY,      // units dps
  accRoll, accPitch,           // units degrees (roll and pitch noisy, yaw not possible)
  complementaryRoll, complementaryPitch;
  Wire.begin();
  byte status = mpu.begin();
  Serial.print(F("MPU6050 status: "));
  Serial.println(status);
  while (status != 0) {}  // stop everything if could not connect to MPU6050
  Serial.println(F("Calculating offsets, do not move MPU6050"));
  mpu.calcOffsets(true, true);  // gyro and accelero
  Serial.println("Done!\n");
  mpu.update();
  accelX = mpu.getAccX();
  accelY = mpu.getAccY();
  accelZ = mpu.getAccZ();
  gyroX = mpu.getGyroX();
  gyroY = mpu.getGyroY();
  gyroZ = mpu.getGyroZ();
  unsigned long currentTime = micros();
  lastInterval = currentTime - lastTime;  // expecting this to be ~104Hz +- 4%
  lastTime = currentTime;
  doCalculations();
  Serial.println("Roll=");
  Serial.println(complementaryRoll);
  Serial.print("Pitch=");
  Serial.print(complementaryPitch);
  delay(10);
void doCalculations() {
  accRoll = atan2(accelY, accelZ) * 180 / M_PI;
  accPitch = atan2(-accelX, sqrt(accelY * accelY + accelZ * accelZ)) * 180 / M_PI;
  float lastFrequency = (float)1000000.0 / lastInterval;
  complementaryRoll = complementaryRoll + ((gyroX - gyroDriftX) / lastFrequency);
  complementaryPitch = complementaryPitch + ((gyroY - gyroDriftY) / lastFrequency);
  complementaryRoll = 0.98 * complementaryRoll + 0.02 * accRoll;
  complementaryPitch = 0.98 * complementaryPitch + 0.02 * accPitch;
Referencing the "also" portion of your thread, @jremington often advises gyro calibration when readings are found to be "inaccurate" and cites this tutorial:
https://wiki.dfrobot.com/How_to_Use_a_Three-Axis_Accelerometer_for_Tilt_Sensing
