Serial Monitor take readings every 5 mins while loop continues
Hi everyone,
I have completed my fan controller to run a vent fan for:
1 hour on and 1 hour off each day
To only run at day time
To only run at 60% normal speed
you can view it here:
https://github.com/Jasontwd/Remote-Fan-control
However the code I have written only writes to the serial monitor each hour as you would expect.
Im keen to take readings every 5 or 10mins.
What way can I do this.
cheers
jason
My current code is:
#include “DualVNH5019MotorShield.h”
const long oneSecond = 1000; // a second is a thousand milliseconds
const long oneMinute = oneSecond * 60;
const long oneHour = oneMinute * 60;
const long oneDay = oneHour * 24;
DualVNH5019MotorShield md;
int sensorPin = A0; // select the input pin for LDR//
int sensorValue = 0; // variable to store the value coming from the sensor
/*int analogPin = 6;
int val = 0; */
Serial.println(“Dual VNH5019 Motor Shield”);
md.init();
pinMode(6, OUTPUT); //pin connected to the VNH5019 M1EN//
// read the value from the sensor:
sensorValue = analogRead(sensorPin);
Serial.print("LDR light reading of ");
Serial.println(sensorValue); //prints the values coming from the sensor on the screen
if(sensorValue < 300) //setting LDR threshold value//
digitalWrite(6,LOW); //turn VNH5019 off//
else digitalWrite(6,HIGH); //turn VNH5019 ON//
delay(2);
//motor startup//
md.setM1Speed(200);
Serial.println(“M1 Speed 50% Forward”);// 400 is 100%//
Serial.print("M1 current: ");
Serial.println(md.getM1CurrentMilliamps());
Serial.print("Delay: ");
Serial.println(“delay for 1 Hour ON”);
delay(oneHour);
digitalWrite(6,LOW); //turn VNH5019 OFF//
delay(2);
//motor shutdown//
md.setM1Speed(0);
Serial.println(“M1 Speed 0% stopped”);
Serial.println(“delay for 1 Hour OFF”);
delay(oneHour);
Don't use delays for timings longer than a couple of ms.
The demo Several Things at a Time illustrates the use of millis() to manage timing. It may help with understanding the technique.
That technique will allow you to operate different things at different time intervals.
...R
