SRJ
July 16, 2022, 3:10pm
1
Hello everyone,
I am working on a project but the problem is,
The data I send from the Bluetooth terminal is not visible on the Serial monitor...
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
BluetoothSerial SerialBT;
const byte numChars = 32;
char receivedChars[numChars]; // an array to store the received data
boolean newData = false;
SerialBT.begin("ESP32test"); //Bluetooth device name
Serial.println("The device started, now you can pair it with bluetooth!");
Serial.println("<Arduino is ready>");
recvWithEndMarker();
showNewData();
void recvWithEndMarker() {
static byte ndx = 0;
char endMarker = '\n';
char rc;
while (SerialBT.available() > 0 && newData == false) {
rc = SerialBT.read();
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
void showNewData() {
if (newData == true) {
Serial.print("This just in ... ");
Serial.println(receivedChars);
newData = false;
The sketch works fine for me
What baud rate do you have the Serial monitor set to and do you see a message on it of any kind when you run the sketch ?
SRJ
July 17, 2022, 9:13am
4
Hiii,
Thanks for your reply UKHeliBob,
The code is working for SERIAL monitor...
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
but when I use SerialBT instead
Serial monitor does not show messge...
This is the problem
& also I have chaeked BAUD rate of my serial monitor.
Serial monitor prints all other message like
<Arduino is ready>
It is just not printing message I send from SERIAl monitor Bluetooth.
Presumably the ESP32 can be paired with the 'phone and the device can be selected in the Bluetooth monitor app ?
SRJ
July 17, 2022, 9:40am
6
Yes sir,
I connect the ESP32 to my mobile...
& then tried to send a number from mobile to ESP32 but the received data is not visible on the SERIAL MONITOR
I apologise for being pedantic, but please describe exactly the steps you used to pair the ESP32 with the mobile (Ardroid or IOS ?), which app you are using on the mobile, how you selected the device to use in the app and how you sent the data from the app
SRJ
July 17, 2022, 10:05am
8
I am using Android.
I am using a app name ArduTooth.
then I selected my device named 'ESPtest'
then I select for TERMINAL option.
& entered serial terminal...
then I typed 12345
and after I send data.
THAT'S all.
SRJ
July 17, 2022, 10:15am
9
My SERIAL-MONITOR is just showing this.
I can't find that app in the Play Store by that name. Its actually appears to be called "Arduino Bluetooth Terminal" by Frederik Hauke. I have installed it but, like you, it does not work for me unless I expressly end the message with a carriage return, which is what the sketch is looking for
SRJ
July 17, 2022, 10:59am
11
Can you spot any mistake in the code I am using ???
Are you ending the message with a Carriage Return in the app ? The sketch will not work without it because it will never know that the message is complete
SRJ
July 17, 2022, 11:22am
14
No I am not using any Carriage Return
Then the sketch will never know that the end of message has been reached and print it
Try ending the message with a Carriage Return.
Press
in the app before you press
to send the message
Odd
Let's try an experiment
In the sketch change this line
to
char endMarker = '.';
upload the revised code and when you enter the message in the Bluetooth Terminal end it with a full stop before you send it
Report back what happens
What exactly worked ?
It should work with '\n' as the end marker as long as you send it from the Bluetooth terminal using the
button at the end of the message before you send it
