i made a sketch of blinking led according to my own time related with variables.
i wrote code also to display variable in serial monitor, as when i changed them from buttons,
but variable are not being changed (& not being displayed in serial monitor) same time on pressing buttons,.they are wait till led on led off function end. i want to make change in variable & display it on serial monitor at same time ,when i pressed buttons,although led on led off function complete or not. and want to do that function with changed variable, when button is pressed,?? because timing in my loop of led (on to off/ off to on ) can be large..
what changes should be done in sketch????
int led = 13;
long ontime;
long offtime;
int a = 0;
int b = 0;
long onsecond = 0;
// long offsecond = 0;
// the setup routine runs once when you press reset:
pinMode(led, OUTPUT);
pinMode(8, INPUT_PULLUP); // SKIP BUTTON
pinMode(9, INPUT_PULLUP);
pinMode(10, INPUT_PULLUP);
pinMode(11, INPUT_PULLUP);
pinMode(12, INPUT_PULLUP);
if (digitalRead(8) == LOW) // IF BUTTON NOY PRESSED
Serial.println("Setup Running");
digitalWrite(led, HIGH); // turn the LED on for 7:53
delay(473000);
digitalWrite(led, LOW); // turn the LED off for 1:07
delay(67000);
Serial.println("Setup Skipped");
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
long ontime = 1000 + (a*1000);;
long offtime = 1000 + (b*1000);;
long onsecond = (ontime/1000);;
long offsecond = (offtime/1000);
int Mode = 0;
if (digitalRead(9) == LOW)
a++;
if (digitalRead(10) == LOW)
a--;
if (digitalRead(11) == LOW)
b++;
if (digitalRead(12) == LOW)
b--;
if ( ontime<1000)
ontime = 5000;
if ( offtime<1000)
offtime = 5000;
Serial.print(onsecond);
Serial.print("------");
Serial.print(offsecond);
Serial.println(" ");
switch (Mode) {
case 0:
delay(ontime); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
delay(offtime); // wait for a second
delay(1);
