Serial Monitor
Serial monitor is from arduino.exe Any other way to monitor the result without using the serial monitor or without the arduino.exe?
Thanks!
Any terminal program should work. I have used screen on my MAC.
I am not a cs guy. Can you mind to help me understand more about terminal program? Im using windows 7, how to ...?
Try hyper terminal. http://www.hilgraeve.com/hyperterminal/
(deleted)
mparduino: I am not a cs guy. Can you mind to help me understand more about terminal program?
This link has a lot of useful information: http://lmgtfy.com/?q=windows+terminal+program
I’m a real fan of Brey terminal program. It’s a small standalone EXE program that even works on my new windows 8.1 laptop. Lots of features and power.
PuTTY
Probably the easiest one to use and understand.
It lets you see what data is being sent over a connection, most commonly used is serial (com ports).
THANKS retrolefty AND ALL OTHERS! I am trying Brey terminal, but it is missing some words or characters: You can see below, first 4 lines are right format, but the others look crazy!
Duty cycle = 70% RPM = 4098
Duty cycle = 80% RPM = 4378
cy90% RPM = 4521
Duty cycle = 100%
RP4699
WaveII_B - Calculating fan RPM(s)
Duty cycle = 10% =1292
Duty cycle = 20% RPM =2386
e = 30% = 30% RPM2883
cycle = 40% cle = 3220
e = 50% = 50% RPM3612
ty cycle = 60% = y3867
cycle = 70% ycle 4078
Duty cycle = 80% R4353
le = 90% = 90% R4516
= 100% 100% RPM 4685
There is no flow control with Arduinos.
If you send data as fast as possible then some can be lost.
So, how can we fix this issue?
Implement some flow control (handshaking) or change the serial speed.
// Per.
