Serial motor control
I am having an issue with the code below for my tank where whenever a motor goes into reverse it doesn't brake when it's supposed to... I am probably overlooking something simple, I would very much appreciate if anybody can help me out.
moving forward, is fine.
turning left/right, the motor that is reversing will run without stopping.
moving backward, both will run without stopping.
// Firmware for the Android Shield Board for tank robots
// Pan/tilt servos now work: 0 pin off, 255 pin on, 1~254 8 bit granularity servo movement (5 microseconds).
#define LeftMotorPWM 11
#define RightMotorPWM 6
#define LeftMotorDIR 3
#define RightMotorDIR 5
#define ServoPin1 0
#define ServoPin2 0
#define ServoFlip1 false
#define ServoFlip2 false
#define mySerialSpeed 9600 // arduino 2009: 4800 or lower!
#define debugSerialSpeed 9600 // arduino 2009: 4800 or lower!
#define BufferLength 16
#define LineEnd1 13
#define LineEnd2 10
#define ServoTimingStep 5
#define ServoCenter 1500
#define ServoTimingFloor ServoCenter-(127*ServoTimingStep)
//#define serialout
#define debugout
#include <SoftwareSerial.h>
SoftwareSerial mySerial(12, 255); // rx only
char charin = 80;
char inputBuffer[BufferLength];
int value = 128;
int speed = 128;
int timer = 15;
int timermax = 15;
int inputLength = 0;
int servoval1 = 127;
int servoval2 = 127;
int tempval1, tempval2;
  // motor pins must be outputs
  pinMode(LeftMotorPWM, OUTPUT);
  pinMode(RightMotorPWM, OUTPUT);
  pinMode(LeftMotorDIR, OUTPUT);
  pinMode(RightMotorDIR, OUTPUT);
  mySerial.begin(mySerialSpeed);
#ifdef debugout
  Serial.begin(debugSerialSpeed);
#endif
// process a command string
void HandleCommand(char* input, int length)
#ifdef debugout
  Serial.print(">");
  Serial.print(input);
  Serial.print("<");
  Serial.print(length);
  Serial.println("|");
#endif
  if (length < 1) { // not a valid command
    return;
  // calculate number following command (d10~d255)
  if (length > 1) {
    value = atoi(&input[1]);
    if (value > 255)
      value = 255;
    if (value < 0)
      value = 0;
    switch(input[0])
    case 'd':
    case 'D':
      if (value > 127)
        value = 127;
      speed = value*2;
    case '/':
      timermax = value;
    case 'c':
    case 'C':
      #ifdef ServoFlip1
      servoval1 = 256 - value;
      #else
      servoval1 = value;
      #endif
    case 'v':
    case 'V':
      #ifdef ServoFlip2
      servoval2 = 256 - value;
      #else
      servoval2 = value;
      #endif
    default:
  timer = timermax;
  int* command = (int*)input;
  // check commands
  // note that the two bytes are swapped, ie 'RA' means command AR
  switch(*command) {
  case '2':
  case '2j':
  case '2J':
    analogWrite(LeftMotorPWM,100);
    digitalWrite(LeftMotorDIR,HIGH);
    analogWrite(RightMotorPWM,100);
    digitalWrite(RightMotorDIR,HIGH);
  case '8':
  case '8j':
  case '8J':
    digitalWrite(LeftMotorDIR,LOW);
    digitalWrite(RightMotorDIR,LOW);
  case '6':
  case '6j':
  case '6J':
  case '4':
  case '4j':
  case '4J':
  case '9':
  case '9j':
  case '9J':
    analogWrite(RightMotorPWM, speed);
    digitalWrite(RightMotorDIR, HIGH);
  case '1':
  case '1j':
  case '1J':
    digitalWrite(RightMotorDIR, LOW);
  case '3':
  case '3j':
  case '3J':
    analogWrite(LeftMotorPWM, speed);
    digitalWrite(LeftMotorDIR, HIGH);
  case '7':
  case '7j':
  case '7J':
    digitalWrite(LeftMotorDIR, LOW);
  default: // stop, just to be safe
    analogWrite(LeftMotorPWM, 0);
    analogWrite(RightMotorPWM, 0);
  // get a command string form the mySerial port
  inputLength = 0;
  do {
    while (!mySerial.available()){
      // note: arduino cannot handle fullduplex on myserial so no output here!
      // do servos here
      tempval1 = (servoval1*ServoTimingStep) + ServoTimingFloor;
      tempval2 = (servoval2*ServoTimingStep) + ServoTimingFloor;
      if (servoval1 > 0)
        digitalWrite(ServoPin1,HIGH);
      delayMicroseconds(tempval1);
      if (servoval1 < 255)
        digitalWrite(ServoPin1,LOW);
      if (servoval2 > 0)
        digitalWrite(ServoPin2,HIGH);
      delayMicroseconds(tempval2);
      if (servoval2 < 255)
        digitalWrite(ServoPin2,LOW);
      delayMicroseconds(5000 - tempval1 - tempval2);
      delay(15); // reduce/remove if we're doing more things here
      // decrease the timer
      if (--timer < 0)
        timer=0;
    // wait for input
      charin = mySerial.read(); // read it in
#ifdef debugout
        Serial.print(charin);
        tempval1 = charin;
        Serial.println(tempval1);
#endif
      if ((charin > 46 && charin < 58) || (charin=='d') || (charin=='j') || (charin=='c') || (charin=='v'))
        inputBuffer[inputLength]=charin;
        inputLength++;
#ifdef serialout
        mySerial.print("$PD,11,");
        mySerial.print(timer);
        mySerial.print(",");
        mySerial.print(value);
        mySerial.println("*");
#endif
  while (charin>46 && charin<119 && charin != LineEnd1 && charin != LineEnd2 && inputLength < BufferLength);
  inputBuffer[inputLength] = 0; //  add null terminator
  HandleCommand(inputBuffer, inputLength);
  // check commands
  switch(*command) {
WTF? Casting a char pointer to an int pointer is really NOT a good idea. The pointers don't point to the same size values. The values being tested then are NOT ints!
  case '2j':
  case '2J':
The Arduino does not support multibyte characters. These cases will NEVER happen.
There's really something wrong with the logic when there are this many conditions for stopping or continuing. Comparing a character to a numerical value is silly. Do you have a 46 key on your keyboard? A 119 key? My keyboard seems to be missing them.
Wrong. The array should be NULL terminated ALL the time, not just when this overly complicated do/while (which is the wrong construct, anyway) ends.
It does, but I don't recommend using them.
I suggest a code tidy-up.
Thanks for the response guys.
Holy Heck, sounds like there are a lot of holes in this code. I didn't write it, and I am battling to figure out how the serial aspect works and how to fix it.
