Serial MP3 Player and nodeMCU V3 Tutorial
I would like to know if somebody has successfully setup a simple program in order to play one sound
or know if an interesting and working tutorial exists ?
with these kind of parts:
DFPlayer Mini
or
YX6300 YX5300 UART Control Serial Module MP3 Music Player
and
V3 Nodemcu-CH340
I notice that with cannot use software serial base library but
we have to use
I try and have no specific errors but even simples examples are not working.
With arduino uno boards no issues.
I use ports RX(D5/GPIO14) AND TX(D6/GPIO12)
If some peoples are interested I'll post code samples when I will make it work.
Best Regards,
guillaumebertrand52:
Wouldn't it be better to post your code that isn't working so people can see what you have attempted and possibly help?
Ok; you are right.
I (try) use this
SerialMp3PlayerControl.ino
==> with an arduino uno it is working.
==> with a nodemcu with espsoftwareserial it is not working
I use version 6.8.0 of espsoftwareserial
The only change I made here
are the ports (with arduino uno no issues)
and due to the usage of espsoftware serial (I put the files in src of the library (espsoftwareserial/src at main · plerup/espsoftwareserial · GitHub)) at the root with the ino file) I change the first line
from
#include <SoftwareSerial.h>
to
#include "SoftwareSerial.h"
No compilation erros but seems to have execution errors (I am a beginner in arduino).
If you're using an ESP32, why not use the extra hardware UART serial ports?
If you want to use the DFPlayerMini, I suggest using the easy to implement library DFPlayerMini_Fast.h. It is installable via the Arduino IDE's Libraries Manager and comes with the following example:
#include <DFPlayerMini_Fast.h>
SoftwareSerial mySerial(10, 11); // RX, TX
DFPlayerMini_Fast myMP3;
  mySerial.begin(9600);
  myMP3.begin(mySerial);
  Serial.println("Setting volume to max");
  myMP3.volume(30);
  delay(20);
  Serial.println("Playing track 1 for 5 sec");
  myMP3.play(1);
  delay(5000);
  Serial.println("Sleeping for 5 sec");
  myMP3.sleep();
  delay(5000);
  Serial.println("Waking up");
  myMP3.wakeUp();
  Serial.println("Looping track 1");
  myMP3.loop(1);
  //do nothing
The example uses a software serial port, but you can use Serial1 instead.
Thanks I will try.
Have a nice day.
I will respond when this as been solved.
