Serial MP3 Player Implementation
I’ve recently got a Catalex Serial MP3 Player and I have not had any success implementing it on my own. I’m following the BasicCommands example, and although my code seems to match the example, it doesn’t want to play, and it doesn’t show any errors. Here’s my code:
#include "SerialMP3Player.h"
#include <SPI.h>
#include <RF24.h>
#define TX 11
#define RX 10
SerialMP3Player mp3(RX,TX);
RF24 radio(9, 10);
const uint64_t pipe = 0xE6E6E6E6E6E6; // Needs to be the same for communicating between 2 NRF24L01
float data[10];
int red = 5;
int blue = 4;
int white = 3;
long audioDelayPeriod = 10000;
long audioDelay = 0;
long whiteDelay = 0;
boolean playingSFX = false;
  digitalWrite(red, HIGH);
  radio.begin(); // Start the NRF24L01
  mp3.showDebug(1);
  Serial.begin(9600);     // start serial interface
  mp3.begin(9600);        // start mp3-communication
  delay(500);             // wait for init
  mp3.sendCommand(CMD_SEL_DEV, 0, 2);   //select sd-card
  radio.openReadingPipe(2,pipe);
  radio.startListening(); // Listen to see if information received
  pinMode(red, OUTPUT);
  pinMode(blue, OUTPUT);
  pinMode(white, OUTPUT);
  mp3.playSL(2,1);
  if (false) {
    playingSFX = true;
    playingSFX = false;
  if (radio.available()) {
    radio.read(&data, radio.getDynamicPayloadSize());
    if (data[6] == 1) {
      mp3.playSL(2,8);
  if (!playingSFX){
    if (audioDelay > audioDelayPeriod){
      audioDelayPeriod = random(5000, 10000); //set delay period
      mp3.playSL(1,random(1, 32));
      audioDelay ++;
Example:
#define TX 11
#define RX 10
  mp3.showDebug(1);       // print what we are sending to the mp3 board.
  menu('?',0); // print the menu options.
 char c;  // char from Serial
 char cmd=' ';
 char cmd1=' ';
// the loop function runs over and over again forever
  if (Serial.available()){
    c = Serial.read();
    decode_c(); // Decode c.
  // Check for the answer.
  if (mp3.available()){
    Serial.println(mp3.decodeMP3Answer()); // print decoded answers from mp3
void menu(char op, int nval){
  // Menu
  switch (op){
    case '?':
    case 'h':
        Serial.println("SerialMP3Player Basic Commands:");
        Serial.println(" ? - Display Menu options. ");
        Serial.println(" P01 - Play 01 file");
        Serial.println(" F01 - Play 01 folder");
        Serial.println(" S01 - Play 01 file in loop");
        Serial.println(" V01 - Play 01 file, volume 30");
        Serial.println(" p - Play");
        Serial.println(" a - pause");
        Serial.println(" s - stop ");
        Serial.println(" > - Next");
        Serial.println(" < - Previous");
        Serial.println(" + - Volume UP");
        Serial.println(" - - Volume DOWN");
        Serial.println(" v15 - Set Volume to 15");
        Serial.println(" c - Query current file");
        Serial.println(" q - Query status");
        Serial.println(" x - Query folder count");
        Serial.println(" t - Query total file count");
        Serial.println(" r - Reset");
        Serial.println(" e - Sleep");
        Serial.println(" w - Wake up");
    case 'P':
        Serial.println("Play");
        mp3.play(nval);
    case 'F':
        Serial.println("Play Folder");
        mp3.playF(nval);
    case 'S':
        Serial.println("Play loop");
        mp3.playSL(nval);
    case 'V':
        Serial.println("Play file at 30 volume");
        mp3.play(nval,30);
    case 'p':
        mp3.play();
    case 'a':
        Serial.println("Pause");
        mp3.pause();
    case 's':
        Serial.println("Stop");
        mp3.stop();
    case '>':
        Serial.println("Next");
        mp3.playNext();
    case '<':
        Serial.println("Previous");
        mp3.playPrevious();
    case '+':
        Serial.println("Volume UP");
        mp3.volUp();
    case '-':
        Serial.println("Volume Down");
        mp3.volDown();
    case 'v':
        Serial.println("Set to Volume");
          mp3.setVol(nval);
          mp3.qVol();
    case 'c':
        Serial.println("Query current file");
        mp3.qPlaying();
    case 'q':
        Serial.println("Query status");
        mp3.qStatus();
    case 'x':
        Serial.println("Query folder count");
        mp3.qTFolders();
    case 't':
        Serial.println("Query total file count");
        mp3.qTTracks();
    case 'r':
        Serial.println("Reset");
        mp3.reset();
    case 'e':
        Serial.println("Sleep");
        mp3.sleep();
    case 'w':
        Serial.println("Wake up");
        mp3.wakeup();
void decode_c(){
  // Decode c looking for a specific command or a digit
  // if c is a 'v', 'P', 'F', 'S' or 'V' wait for the number XX
  if (c=='v' || c=='P' || c=='F' || c=='S' || c=='V'){
    cmd=c;
  }else{
    // maybe c is part of XX number
    if(c>='0' && c<='9'){
      // if c is a digit
      if(cmd1==' '){
        // if cmd1 is empty then c is the first digit
        cmd1 = c;
      }else{
        // if cmd1 is not empty c is the second digit
        menu(cmd, ((cmd1-'0')*10)+(c-'0'));
        cmd = ' ';
        cmd1 = ' ';
    }else{
      // c is not a digit nor 'v', 'P', 'F' or 'S' so just call menu(c, nval);
      menu(c, 0);
When I run the example it works exactly as planned, but when I run mine, it is silent. Please help!
  if (false) {
    playingSFX = true;
    playingSFX = false;
This part will always evaluate to playingSFX = false. I assume you did not intend the if(false) in this
You might also find it slightly easier/faster to use DFPlayerMini_Fast.h as your MP3 driver library
hzrnbgy:
  if (false) {
playingSFX = true;
   playingSFX = false;
This part will always evaluate to **playingSFX = false**. I assume you did not intend the **if(false)** in this
Actually that is intended, but only as temporary until I can figure how to get the status of the mp3 module (e.g. playing, stopped, etc.)
Power_Broker:
I'll try that, thanks.
Power_Broker:
Does it matter that I'm not using the DFPlayer Module? I'm using the Catalex Serial MP3 Player Module.
