I have an Arduino Mega and have had no problems until I tried using an external power supply for the first time tonight. I'm simply trying to use a parallax RFID reader and my sketch works fine when the board is connected through USB, however, when connected to only an external power supply, the code seems to execute but the serial part does not work.
My Code:
int val = 0;
char code[10];
int bytesread = 0;void setup() {
pinMode(52,OUTPUT); //Enable/Disable RFID pin
pinMode(13,OUTPUT); //LED used to make sure the loop is running
digitalWrite(52, LOW); //Enable the RFID
Serial1.begin(2400); //Arduino Mega RX1 (Pin 19) connected to SOUT from RFID reader
}void loop() {
digitalWrite(13, HIGH); //Blink the LED to show we're in the loop
delay(100);
digitalWrite(13, LOW);
delay(100);if(Serial1.available() > 0) { // if data available from reader
if((val = Serial1.read()) == 10) { // check for header
bytesread = 0;
while(bytesread<10) { // read 10 digit code
if( Serial1.available() > 0) {
val = Serial1.read();
if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
break; // stop reading
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
if(bytesread == 10) { // if 10 digit read is complete
digitalWrite(52, HIGH); // Disable and re-enable after 2 seconds when a card has been read
delay(2000);
digitalWrite(52,LOW);
bytesread = 0;
delay(500); // wait for a second
When connected through USB the pin13 light blinks as it should and when a card is held up, the parallax led goes from red to green for 2 seconds then changes back. Perfect.
When connected through an external power supply, the pin13 light blinks which means the sketch has made it into the loop, but nothing happens when I hold a card up to the RFID reader.
Any thoughts/suggestions would be greatly appreciated.
