[edit] While creating this post I figured out that if I set the below to "+1" it works, can someone explain to me why? Do I have to add an extra array slot for the serial stream string termination character?
*char serialInCharArr[serialInString.length() + 1];*
*serialInString.toCharArray(serialInCharArr, (serialInString.length() + 1));*
I can't figure out why the last character of my serial stream is always unrecognizable? The IDE displays it as a rectangle. I believe it has something to do with string termination, but I can't figure out why?
Below the console output is repro code. I have it set to 9600 baud and Both NL & CR .
0:43:56.387 ->
10:43:56.387 -> ***** Start *****
10:43:56.387 ->
10:44:01.296 -> New BT data: <sundays=disabled>
10:44:01.441 -> serialInString.length(): 18
10:44:01.442 -> 0 - <
10:44:01.442 -> 1 - s
10:44:01.442 -> 2 - u
10:44:01.442 -> 3 - n
10:44:01.443 -> 4 - d
10:44:01.443 -> 5 - a
10:44:01.443 -> 6 - y
10:44:01.443 -> 7 - s
10:44:01.444 -> 8 - =
10:44:01.444 -> 9 - d
10:44:01.444 -> 10 - i
10:44:01.444 -> 11 - s
10:44:01.444 -> 12 - a
10:44:01.478 -> 13 - b
10:44:01.478 -> 14 - l
10:44:01.478 -> 15 - e
10:44:01.498 -> 16 - d
10:44:01.498 -> 17 - □
10:44:05.948 -> New BT data: <sundays=enabled>
10:44:06.082 -> serialInString.length(): 17
10:44:06.082 -> 0 - <
10:44:06.082 -> 1 - s
10:44:06.083 -> 2 - u
10:44:06.083 -> 3 - n
10:44:06.098 -> 6 - y
10:44:06.098 -> 7 - s
10:44:06.098 -> 8 - =
10:44:06.098 -> 9 - e
10:44:06.098 -> 10 - n
10:44:06.128 -> 11 - a
10:44:06.128 -> 12 - b
10:44:06.128 -> 13 - l
10:44:06.128 -> 14 - e
10:44:06.158 -> 15 - d
10:44:06.158 -> 16 - □
#include <EEPROM.h>
#include <SoftwareSerial.h>
SoftwareSerial BTSerial(12, 13); // RX , TX
// Serial In/Out Variables
String serialInString;
boolean newData = false;
BTSerial.begin(9600);
while (!Serial)
; // Wait for serial to connect
while (!BTSerial)
; // Wait for BTSerial to connect
delay(2000);
Serial.println("");
Serial.println(" ***** Start ***** ");
Serial.println("");
while(BTSerial.available() > 0 && newData == false)
serialInString = BTSerial.readString();
Serial.print("New BT data: "); Serial.println(serialInString);
Serial.print("serialInString.length(): "); Serial.println(serialInString.length());
char serialInCharArr[serialInString.length()];
serialInString.toCharArray(serialInCharArr, serialInString.length());
//String serialInStringArr[100];
String bleh = "";
for (int i = 0; i < serialInString.length(); i++)
Serial.print(i); Serial.print(" - "); Serial.println(serialInCharArr[i]);
if (serialInCharArr[i] == '<')
bool startCharFound = true;
bleh = "";
else if (serialInCharArr[i] == '>')
bool endCharFound = true;
Serial.print("End char found. String is: "); Serial.println(bleh);
bleh = bleh + serialInCharArr[i];
//myString.toCharArray(buf, len)
newData = true;
//Serial.println(serialInString.startsWith("alldaystime"));
delay(15);
delay(5);
newData = false;
